Charger
Old 10-23-2001, 06:17 AM
  #31
Default Hi
HI Moses,
Definitely not the Melvin u know. Do you mean Cisco as in the routers, switches network manufacturer ?
Melvin
Originally posted by signoftimes
I'll be calling MRC in the U.S. in a while's time. Will let you know after that.
My name is Moses. Your name sounds familiar. It sounds like someone that I know from my previous job. If you're not that person that I think I know, you probably don't know me coz I don't go racing. Just like the R/C stuff which I just started in February this year.
Did you use to come from Cisco Systems?
melvin is offline
Old 10-23-2001, 07:55 AM
  #32
Melvin,
Found that the Super Brain 959 accepts only 120V at 60 cycles. That means a step-down transformer is required to operate the charger.
Do you know where to buy one like the one that I just mentioned to run step down to 120V at 60 cycles? And how much would that cost?
signoftimes is offline
Old 10-23-2001, 08:02 AM
  #33
Melvin,
Yes, Cisco as in routers and switches. So are you in the IT industry too? How do you know about routers and switches?
So do you race or do R/C for leisure only?
Old 10-23-2001, 06:13 PM
  #34
Yes , i am in IT but I am not familiar with Cisco. I was doing the CCNA myself early this year but I stopped because of busy schedule. Are you a Cisco trained personnel ?
How's the feedback from MRC ?
Melvin,
melvin is offline
Old 10-23-2001, 06:18 PM
  #35
Moses,
I already have a step down transformer myself But one cost about $30 - $ 60 if i remember correctly. You should try hunting i down in Sim Lim Tower for better price.
Melvin,
melvin is offline
Old 10-23-2001, 06:23 PM
  #36
Buy 2 charger and connect them in series into the mains 240AC !!! It works !!! no need to buy a step down transformer.
Kasey is offline
Old 10-23-2001, 08:42 PM
  #37
Kasey,
Thanks for the info!
Melvin,
Yeah, I attended the ICND for Cisco, but didn't get to do the CCNA exam.
About the transformers sold at Sim Lim at $30/$40, are they reliable? What about the 60 cycles that I mentioned earlier? Did you notice the 13.8V regulated transformer mentioned by "Nipple" that cost $200+ or $300_+? I wonder what that is man.
Old 10-24-2001, 03:19 AM
  #38
Alvin's Avatar
if I am not mistaken, regulated power supplys' output is much closer to a constant voltage level.
i.e. the ripple voltage at the output is much attenuated.
Alvin is offline
Old 10-24-2001, 05:35 AM
  #39
I see. That means to say it is quite consistently running at say, 60 cycles instead of highs and lows, right?
Old 10-24-2001, 06:42 AM
  #40
Default Eagle CDC
Hi guys,
what about Eagle CDC charger ? looks pretty good. but a bit
expensive.
I was thinking of doing a programmable peak charger
using a micro-controller. Just do a constant current source
and measure the voltage delta over time.
Didn't have the time to do it though.
ongbenghui is offline
Old 10-24-2001, 04:44 PM
  #41
Hi guys.... hmmm eagle CDC ... MY CHARGER...... ok... it is quite good as in it can set to NImh and NIcd, charge at 0.1A to 10.A, 3-8 cells, delta peak detection at 3mV to 20mV, 12V DC input (there is a AC/DC version) discharge rate up to 20mAh. its all in one and it works pretty fine, it can detect open circuits, reverse batteries and other faults(overheating) and shut down on its own.
Madman is offline
Old 10-24-2001, 04:56 PM
  #42
Madman.
How much does the Eagle CDC cost and who's selling it in S'pore?
I heard from a friend that NiMH batteries don't like to be cycled (discharged completely and re-charged). Any advice or tech documents on how to maintain 3000mAh NiMH batteries well?
Old 10-24-2001, 06:14 PM
  #43
NImh... hmmm ok its true that nimh dun like to be discharged till near 'zero' volt condition. so Always store them with 1/3 the capacity they can carry. Also when you charge Nimh regardless of what charger, it is always good to have a ttemperature probe to monitor the heat of your cells. somewhere below 50 degs is ood. Anything too much higher will dmg the cells
The eagle is about mid 200-300ish and elite models at orchard plaza sels them, if stocks permits that is. They got a AC/DC version of it too but its huge, like carrying a 12 v batt I think. You can go down and take a lok at it took.
Madman is offline
Old 10-24-2001, 07:03 PM
  #44
Joehwee's Avatar
Madman: The CDC charging amp is from 0.1A - 7A in 0.1 amp increment. And charge 4-8 cells. As for shutting down on it own, I don't seem to see the feature available on my unit.
Joehwee is offline
Old 10-24-2001, 07:15 PM
  #45
Alvin's Avatar
I guess what Madman meant is when it detects faults like uh, open cct or battery suddenly disconnected while charging, it will just stop.
Hey, dudes with the CDC, can u tell me what settings u guys use for Sanyo 3ks? Mine I think spoilt liao, overheated. I charge at 5A with 3mv/C, capacity at most can only get about 2600mAh
My 2k nicad and 3k GP cell no problems, all > than their rated capacity.
Regards,
Alvin
Alvin is offline
