How do I break in Acer Bearings
I just got my set of acer bearings (their ceramic pro nitride series), and I need some suggestions on how to break them in?
Btw, their red seal ones are the pro nitride series right? how bout yellow? also pro nitride? (I am not sure does size of the bearings dictate their seal colors or does quality of bearings do that.)
I have been recieving conflicting advice about breaking in ceramics, so I just want to hear some reasoning on why different people have selected different methods.
Thanks.
Thanks.
I was under the impression that ceramic bearings needed no oil and in fact oil may dampen their performance.
Is that not true?
Is that not true?
Here's a thought..... Contact Acer directly! They should be able to tell you the CORRECT way to take care of and break-in thier product. This way you don't get conflicting answers.
Is that not true?
Is that not true?
For the longest life and smoothest operation of your Acer Ceramics, run them exactly as you got them from Acer. Don not clean them and relube them...run then with the thick factory lube in them. After aboiut 15-20 packs, they will be broken in and then you can clean and relube them.
Ceramic bearings do need oil. The difference between ceramic and steel bearings is that ceramic bearings are lighter, stronger and can take higher temperatures than steel!
One drop of the Acer SIN oil is all that is needed and it will not have a negative effect on performance! But yes, they do need oil if you want them to last!
Good luck getting ahold af Acer! i bought a set just like you descibed, i put them in and you could hardly turn the wheels, or diffs, i tried calling them, Email, fax finallly 3 days later someone called me back, we talked and he told me to remove one side of the seal and really clean the grease out of them, even soak them overnight, then use a quality bearing lube, reinstall in the car and run it about half or less throttle for about 5-10 packs with the wheels off, didn't work! so i tried the whole process over again with the same results, so i sent them back for a refund, for $100.00+ bearings they should be ready to zing right out of the package.
Wow, i've bought 5 sets of the Pro-nitride for 4 different cars and i havn't had any problems at all... For the price they're superb, BOCA seems a bit overprized...
Yeah, I have never had any problems at all with Acer. I currently run their ceramics in every car I own. I never had a problem with their customer service either.
As far a being ready to "zing" right out of the package...well I don't have a problem with breaking them in. I mean, we have to assemble batteries, break in motors, build cars...what difference does it make. Buy any other manufactures bearings you still would have to clean and relube the bearings when they are new to get them to "zing."
But once Acer's are broken in they get better and better!
Go through a little break in period and you'll be very happy!
Do the bearings actually need to have stress placed on them from racing or can you just hook up a charger and motor and just run the motor for a really long time?
The first time i used the acer berings i thought they sucked. but once i ran them for a while they were great and still are.
Yeah, they seem a little stiff when brand new becuase of the seals that Acer uses. Once they are broken in however, they are the best bearings and the best seals you will find. Very, very little maintenance. They keep dirt and carpet fibers out of the bearings better than any other shield out there.
I would put packs through them on the track. Trust me, they are still smooth out of he box and you will not notice them slowing you down. In fact, when new, they are about as smooth as any other new bearing you could buy but after 15-20, nothing can touch them.
thankyou very much for all the replies.
yea.... for the person that gave me the "here's a though..."... contacting ACER by email is near impossible. I couldn't even get a ABEC grade from them after 2 weeks.
I think I will break them in by running them for about 10 runs, then spraying them out and re-lubing them w/ some sin oil.
Question though... How should I spray them out?? take off seal? with seal?
