Go Back  R/C Tech Forums > International Forums > Australian Racing
How to protect CF Bottom decks >
Old 01-28-2004 | 05:36 PM
Kennedy's Avatar
From: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Default How to protect CF Bottom decks
Hi Guys,
I was just wondering if anyone had any brilliant ideas they would like to share about ptoective layers on ur bottom deck. I've seen people use "contact" like substance or people gluing thin lexan on aswell and just wanted a few more ideas other than setting ride height to 10mm
Kennedy is offline
Old 01-28-2004 | 06:13 PM
oldnwise's Avatar
Default Re: How to protect CF Bottom decks
I use self adhesive velcro strips. You can buy velcro from most hardware stores and then cut a small piece and place on the sections of your chassis that are getting worn. The velcro needs to be replaced every two to three race meets.
oldnwise is offline
Old 01-28-2004 | 06:26 PM
One neat way to preserve your chassis is by not using it!
The other is to purchase some Sticky Teflon Tape, looks like contact but much thicker.
Made by ( and available locally! ) Associated & Tamiya. So should be easy enough to procure. Cost is less than $20.
Also a thin bead of C/A along the edges will help to preserve your chassis from the side impacts a little.
Cheers.
stuck is offline
Old 01-28-2004 | 06:41 PM
Coxy's Avatar
Go to a Motobike shop and ask for the 3M protection sheet they put on Motocross bikes. Cost about $13 and you will get two chassis out of it. Very very strong stuff and it's clear.
Much cheaper and much much better than the other option.
Coxy.
Coxy is offline
Old 01-28-2004 | 08:18 PM
Rod M's Avatar
there is a adhesive backed aluminum sheets out there somewhere, my dad had some sheets years ago, they are about 0.5mm thick and sounds ideal to protect the chassis,
I will try to find some,
Rod M is offline
Old 01-29-2004 | 12:21 AM
Sounds OK, if not too expensive.
Although it could be worth keeping in mind that metal parts on your car can sometimes generate radio trouble. Worth the experiment I suppose??
stuck is offline
Old 01-29-2004 | 05:40 AM
MrEs's Avatar
that woudl be awsome, if u hit a cone and bottom out bad ud get all sparks from the bottom, HOW COOL WOULD THAT BE!
i think it should be a requirement by all clubs, im sure we would get more spectators.. :P
MrEs is offline
Old 01-29-2004 | 01:38 PM
Kennedy's Avatar
Just put a lighter flint on the bottom deck. Sparks with minimul damage!!!!
Kennedy is offline
Old 03-10-2004 | 06:28 PM
MrEs's Avatar
does that 3m stuff have problems with peeling off when u bottom out?
MrEs is offline
Old 03-11-2004 | 01:54 AM
That 3M stuff sounds cool... thanx coxy...
I wouldn't recommend stick on alloy... Bottoming out will slow your car considerably!
Dragonfire is offline
