Keyence ESC
Regional Moderator
So How do you guys like the keyence zero V extreme?
i like it because its super small. but the programming gets annoying ... u have to program a couple things at one time ... and i find the buttons quite sensitive when u press them so sometimes when u only mean to press it once .. it presses twice for u ... other than that i love it ...
plus it says HELLO when u turn it on
My works great!
I only needed to program it once and haven't worried about it since.
Regional Moderator
thanks guys for the input! anyone else running them???
Regional Moderator
Been using one almost a year now. No problems whatsoever. Biggest hassle is as they said programing it, after that you don't even need to think about it. Yep a little more expensive then the GT7, about $40 worth, but they don't burn down either and finishing the race is what it is all about.
Regional Moderator
and is there anything i need to look out for ?
Regional Moderator
Well let me think about this..........you're in my class........you compete with me........you keep beating me........help?
Sure I'll help you set it up, now if you want to go to advanced settings that may be a different thing, but the basic setup is really easy. Dustin did have one left but I think he sold it. Thats the biggest problem with the ESC finding it. I think Speedtech stocks it.
Regional Moderator
LOL now that isnt the way to be and you beat me
and the one he had I got so im going to try and set this thing up for the 6th after cleaning all the fuzzzzzzz off the car form last weekend if I have trouble you will see me first thing thanks again
I have been using it for 2 months now! so far the best speedo I ever have! You can control alot of things such the freq, min brake, dead band and so on directly on the speedo!
You do not need to install the diode on the motor, since Keyence has a new patented technology!
Try it, you'll like it!
Keyence Zero Extreme series are da BOMB!!!!!!
zero extreme
I have had good luck with mine but, watch extremely low turn motors. do not run the factory setting for stock motors with a mod motor. I did it once and it shut down. once it cooled down, it has been fine since.
