Team Associated RC10B64 Thread >
Like Tree710Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 11-22-2016, 09:20 PM
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Default Team Associated RC10B64 Thread
B64:
Speed, grip, and durability
Designed to take advantage of today's faster-than-ever tracks, the RC10B64D Team Kit offers increased durability, all new suspension geometry, a wider tuning window, improved weight distribution, and easy maintenance. Excelling on high-traction surfaces, the B64D's adjustable axle height and roll centers result in a stable yet nimble platform. With a new and improved center differential, the B64D rewards the driver with maximum drive out of all four wheels on dirt and clay surfaces.
FEATURES:
V2 12mm Big Bore threaded aluminum shocks with 3mm TiN coated shafts and low friction X-rings for improved smoothness
Factory Team floating aluminum motor mount and aluminum/carbon servo mounts
Refined arm mount geometry with quick and easy tuning
Front and rear anti-roll bars keep chassis flat for increased corner speed
Narrow, 7075 hard-anodized aluminum chassis with centralized mass
Strengthened front and rear suspension with hard-anodized aluminum caster blocks and carbon fiber shock towers
Team Associated clear body and screw-mounted wing by JConcepts(TM)
All metric hardware throughout
Easy access center slipper clutch with LCF pads
5mm front wheel aluminum drive hexes
B64D:
Features
Robust suspension arms with multiple shock mounting positions
7075 hard-anodized narrow aluminum chassis with lightweight plastic side guards
Aluminum floating motor mount allows consistent torsional chassis flex
Aluminum/carbon fiber floating servo mount offers a tweak-free assembly
Easy access to differentials allow quick tuning and maintenance
Front and rear anti-roll bars provide flat cornering
Center gear differential maximizes drive out of the corner
12mm aluminum drive hexes in both front and rear
Stiff and lightweight 4mm thick carbon fiber shock towers
Fully adjustable aluminum front and rear suspension arm mounts
Precision-made aluminum caster blocks for added durability
B6 generation ball cups and turnbuckles for precise adjustments and durability
All metric hardware
V2 12mm big bore threaded aluminum shocks with TiN shock shafts
Option to mount rear shocks on either the front or rear of the rear suspension arms
Factory Team upgraded ball bearings
Factory Team Aluminum Shock Bushings provide a stable shock mount base
B64 CLUB RACER:
Features
Reedy Sonic 540 13.5 Fixed Timing motor produces maximum power output and RPM thanks to an all new stator design, pure copper magnet wire, and low-resistance collector rings. ROAR approved and meets BRCA and IFMAR specs.
Reedy's Blackbox 600Z Zero Timing Sensored Brushless Competition ESC is a simple-to-use, yet powerful ESC for Spec class racers. Excellent throttle and brake feel, a wide range of adjustability, and robust hardware make the Blackbox 600Z suitable for a variety of Spec racing applications.
The Reedy 0712MG Metal Gear Digital Servo is race-proven and features numerous enhancements including precision metal gears for added strength and smooth operation, and an advanced microprocessor that improves vehicle control and on-track performance.
Lightweight, hard-anodized aluminum chassis with centralized mass
Graphite front and rear shock towers with multiple mounting positions
3 gear differentials with lightweight internal gears
Rear anti-roll bar included
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
V2 12mm Big Bore threaded aluminum shocks with 3mm shafts and X-rings for improved smoothness
Heavy-duty ball cups and ball studs allow for maximum suspension travel while reducing binding and friction
Factory Team ball bearing kit included
Bolt-on steering block arms offer increased adjust-ability
JConcepts(TM) B64 clear body and wing included
more info on club racer: https://www.youtube.com/watch?v=WZ2ZdVM6f5U
carpetburner likes this.
RCBuddha is offline
Old 11-22-2016, 09:21 PM
RCBuddha's Avatar
FREQUENTLY ASKED QUESTIONS AND ANSWERS
Q: Why are there three kits?
A: One is for dirt (B64D) and one is for astro/carpet (B64). The B64 Club racer is a kit that includes electronics but will still need to be built.
Q: What are the different parts between the B64 and B64D?
A: Springs: B64 purple front/ gray rear B64D yellow front / green rear
Sway bars: B64 yellow front/ orange rear B64D green front / blue rear
Front hexes: B64 5mm (same as rear on both) B64D 3.5mm
Center differential: B64 slipper B64D gear differential
Rear dogbone: B64 95mm (with slipper) B64D 110mm (with gear diff) - front dogbones are 82mm on both
*Special thanks to E-Mann for answer!*
Q:
A:
RCBuddha is offline
RCBuddha's Avatar
AFTERMARKET PARTS:
Arndtcraft:
https://arndtcraft.com/
Krazedbuilds:
Krazed Builds B64 parts
Parts from Shapeways:
B6 Ball cup tool (works with drill)
Ball cup holder
B6 rear lipo brace
Bezerk R/C
Bezerk RC Carbon Fiber parts
RCSpeedsecrets:
http://rcspeedsecrets.com/
Rawspeed R/C:
http://rawspeedrc.com/
Trinity:
https://www.teamtrinity.com/
Diggity R/C:
http://www.diggitydesigns.com/index.html
Xfactory R/C:
http://www.xfactorystore.com/Default.asp
RDRP:
http://revolution-rc.com/
Acer Racing:
https://www.acerracing.com/
Bezerk RC (Australia):
http://bezerk.com.au/shop/
T-Works:
Hard coated pivot ball
Titanium battery post
POM shock bushings shaft guide
POM shock bushings
McKune R/C:
Slipper pads
Vision Racing Products:
Slipper pads
Casper R/C Ceramic Caged Thrust Bearing for Diff:
Casper R/C
Imbue R/C:
12mm Brass pistons
Stick-it1 Graphics (custom name decals)
Stick-it1 Graphics
RCShox:
2-Stage shock pistons
Garodisc Slipper Pads - new style
Garodisc Slipper Pads - old style
Flo Control Pistons
Flo control pistons (Kashima)
Protek:
amain.com
Fastener-Express:
Fastener Express Screws in Bulk
TKO Competition:
http://tkocompetitiondev.com
MIP:
http://www.miponline.com/store/index.html
AVID:
avidrc.com
SCHELLE:
www.schelleracing.com
JCONCEPTS:
http://www.jconcepts.net/
JCONCEPTS (SHAPEWAYS STORE):
https://www.shapeways.com/search?q=jconcepts&type=
LUNSFORD:
https://www.lunsfordracing.com/mm5/merchant.mvc
EXOTEK:
exotekracing.com
PROLINE:
http://prolineracing.com/
OTHER LINKS
Gravity R/C:
.2mm thick shims
Drill-compatible adapter to help spin wheel for bench break-in
Offroad tire break-in kit
Stiky Kicks Tire Sauce:
Sticky Kicks
RCBuddha is offline
Old 11-22-2016, 09:22 PM
RCBuddha's Avatar
USEFUL LINKS
Instruction Manuals:
B64D Manual
Setup Sheets:
B64D Setup sheets
B64 Setup Sheets
Tuning with Camber Links - Long read, and a different way to tune your car, but it can make more sense for some.
Razathorn's Camber Link Tuning Guide
Roll Center explanation by EvanJay
Darcness's Tuning Guide
Martin Crisp's Car Tuning Guide - Onroad oriented, but very informative.
Learnsetup.com - App based setup sheets. Also by Martin Crisp, $10/year subscription.
Anti Squat article
http://users.telenet.be/elvo/ - Great tuning guide, lots of explanations of setup and suspension theory. :
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
RCBuddha is offline
RCBuddha's Avatar
HOW TO/BUILD LINKS
RCBuddha is offline
Old 11-22-2016, 09:23 PM
RCBuddha's Avatar
REFERENCE
RCBuddha is offline
RCBuddha's Avatar
PLACEHOLDER
RCBuddha is offline
Old 11-22-2016, 09:24 PM
Trader Rating: 17 (100%+)
Is this a 4WD B6?
tylem28 is offline
Old 11-22-2016, 09:56 PM
Hopefully its gonna have a better entry to market in germany like the B6....(I dont think so )
man1ac is offline
Old 11-23-2016, 02:15 AM
Trader Rating: 12 (100%+)
Originally Posted by tylem28
Is this a 4WD B6?
Yes the new Associated 4WD Buggy kit.
190mph is offline
Old 11-23-2016, 04:24 AM
Every used B44.x sale just had to drop their price $100
PetRock is offline
Old 11-23-2016, 05:22 AM
I had checked the b44.3 sales yesterday and they are the same price and selling within a day or 2. One of the for sale b44.3 was sweet, it came w/ a ton of parts/spare slipper diff, ball diffs and some nicely painted body's. Same w/ the xb4's they cost twice as much and selling very fast as well.
racingnewb is offline
Old 11-23-2016, 05:58 AM
Trader Rating: 15 (100%+)
looks like they got A LOT of inspiration from the xb4 - little too much if you as me. kinda like the 1/8 scale.
seems like associated isn't innovating as much these days as apposed to other companies.
lyons238 is offline
Old 11-23-2016, 06:05 AM
Finalist's Avatar
That's not how proven engineering works. You are basing your likes and dislikes on visual eye candy rather than performance on the track.
Fishing likes this.
Finalist is offline
Old 11-23-2016, 06:08 AM
Look forward to getting my hands on one of these! Wish they would leave the kit clear like the pictures.
Wil Holmes is offline
