LOSI TYPE R
LOSI TYPE R
Losi Type R – For Sale
This car has only been run on carpet (no scratches on the bottom of the chassis). I have run both foam and rubber tires and this car is awesome.
Included in the deal
Optional front one way
Standard front diff
PRS spur gear adaptor
Front arms (LOSA1217) 5 pair still in package
Rear arms (LOSA2223) 2 pair still in package
Steel Pivot balls (LOSA6054) 1 still in package
3/16 x 3/8 ball bearing (LOSA6903) 2still in package
Body post & bumper set (LOSA4239) one still in package
Front spindles & Carriers (LOSA9762) one set still in package
Rear hub carrier 0 deg (LOSA 9865) one pair still in package
Two complete sway bar kits (front and rear)
10.5 spring one pair
12.5 spring two pair
15.0 spring two pair
17.5 spring two pair
20.0 spring two pair
25.0 spring two pair
30.0 spring two pair
35.0 spring one pair
4 degree caster block one pair out of package
6 degree caster block two pair out of package
Rear hub carriers 0 deg one pair out of package
Steering knuckles one pair out of package
0 degree rear toe pivot block
2 degree rear toe pivot block
Aluminum wheel mount hex all the way around
Other miscellaneous parts included
Package deal $335 shipped to lower 48 states
I don’t have pay pal so payment will be certified check or money order.
Standard front diff
