ONE OF A KIND V ONE RRR FOR SALE! MUST GO!
Hi guys, i'm selling my RRR. I've had the car for over a year and raced with it. The car is very competitive, easy to setup and easy to drive. You won't dissapointed. I just got another car so this one has to go. This baby need a new home, serious buyer only. Then car is well maintained and well taken care of. My loss your gain, ONE OF A KIND RRR, nobody else has this kind of car, let it be you! I'm trying to sell everything as a package, so no parting out, no trade please. I'm asking $450 for everything plus shipping to U.S only. I'll throw in integy setup station and temp gun as well. Prefer USPS money order or paypal (plus paypal sales charge). This is a steal, you don't need to worry about parts for this car anymore. Let me know for pictures. They are pretty big size to post here, just give me the email add. for if you need to see pics.
Here's the break down:
Parts New In Box:
VZ206 Front Suspension Arm Set (2 set)
VZ210 Rear Suspension Arm Set
VZ201 Front Knuckle Arm
VZ209 Rear Bulkhead
FT22B Body mount set
VZ227 2 speed shaft
VZ202 Rear hub
VZ079 Front oneway outdrives
FM524 Servo Saver Shaft (2)
VZ232 Drive belt 180 (2)
VZW201 SP Drive belt 189
FM328-1 Collar (3x8x12mm)
VS033 Swing shaft for wide tire
VZ115-22 Pinion 22T
VZ115-21 Pinion 21T
VZ214-15 Pinion 15T
VZ214-16 Pinion 16T
VZ113-59 Spur 59 T (2)
VZ113-61 Spur 61T (3)
VZ113-60 Spur 60T
VZ114-56 Spur 56T
VZ114-55 Spur 55T
Kyosho RRR with following hop ups:
Kawahara:
Kawahara Chassis (ok condition, still good for few more races).
Kawahara front shock tower
Kawahara handle bar
Kawahara brake lever
Kawahara brake bracket
Kawahara rear stabilizer (blade type)
Kawahara 1st gear housing
Kawahara aluminum brake stopper
Kawahara 1 piece engine mount
3Racing:
3Racing front bulkhead cover
3Racing alum steering servo mount
3Racing alum. throttle servo mount
3Racing front anti roll bar set
3Racing grphite battery base holder
3Racing front and rear titanium hinge pins
3Racing pulley spacers
3Racing titanium 2spd shaft
3Racing graphite receiver plate
K-Factory:
K1909 Special rear mount (alum. & carbon combo)
K1907 4mm Rear carbon shock tower
Skyline:
Skyline 4mm rear shock tower
Skyline alum wheel hex adapter
used parts:
1 stock chassis (great condition)
1 rear differential w/ 10k oil
2 stock rear shock tower
1 skyline 4mm shock tower
2 side belt (used but still good)
2 front upper hinge pins
2 front lower hinge pins
2 rear hinge pins
1 titanium 2spd shaft (3racing)
3 rear dogbones
2 front dogbones
1 pair rear outdrives
4 pcs rear cup joints w/ spacers (to use with 0 offset tires)
2 clutch bell assembled with pinions
1 clutch bell
4 grey cluth shoe
1 red clutch shoe
1 stock 2spd housing
2 1st spur gears
1 2nd spur gears
12 pcs 1st and 2nd pinions (worn out but still good for practice)
1 genuine kyosho pinion tool.
Parts New In Box:
VZ209 Rear Bulkhead
VZ227 2 speed shaft
VZ202 Rear hub
VZ115-22 Pinion 22T
VZ115-21 Pinion 21T
VZ214-15 Pinion 15T
VZ214-16 Pinion 16T
VZ113-60 Spur 60T
VZ114-56 Spur 56T
VZ114-55 Spur 55T
Kawahara:
Kawahara handle bar
3Racing:
K-Factory:
Skyline:
used parts:
2 rear hinge pins
3 rear dogbones
2 front dogbones
1 clutch bell
4 grey cluth shoe
1 red clutch shoe
2 1st spur gears
1 2nd spur gears
