TRINITY's new DPD discharger
#16
Once again will there be a "Cuffs" edition?
#17
Trader Rating: 51 (100%+)
Yo Jeff, how about hookin a brotha up with one of those units hint hint hint
#18
Me too Jeff ...Hook me up!!...BTW I got an RDX now...lookin to play a little carpet with the car ofchoice instead of the t2...
#20
I have the muchmore and with this unit if you disconnect the power with the pack in you will blow the unit, i like the idea of having the AA batteries in and not a power unit, now the numbers on the photo that pack look real nice how about you let a me get that one, lol.
#21
Clicked on the link, have a few questions:
1) How quickly can it dump a pack after a run?
2) Does it have a 5.4 cutoff?
3) Can you select a value for a cutoff per cell? 0.7 or 0.9 for example
Any others specs that you can post about it Jeff would be appreciated.
Thanks.
Thanks.
#22
#23
How long does the 30amp pulse discharge take? If it is a Dyna Pulse rate than this unit does not do much for the cells.
#24
#25
No you don't. The much more only had a problem when you connect the battery in reverse without power.
#27
Ok then try putting a fully charge pack in and then disconnect the power supply and see what happen.
You may have had a defective unit or some other problem.
#28
Originally Posted by CypressMidWest
I dunno, I have experienced great results with my packs using the Dynapulse, it takes a while, but my packs have improved since I started using it, and I imagine being able to do each cell individually will be of even greater benefit.
#29
how long does the AA batteries last? i know dependent on how much you use, but say a week, a month, a year
