Team Losi JRXS
#8206
Originally Posted by DirtyDog3375
I'm looking for more corner speed (especially entry speed) using the Numan setup. (rubbers on asphalt-outdoors) Any ideas??? I have tried using a one-way (diff and pulley) and have also tried a diff, but felt that I had to change my driving style too much.
Also, has anyone tried the Skoda 2 body with a different (higher downforce rear wing)??? I have yet to paint my body up and was thinking of doing so, but from what I can gather, the Skoda 2 provides plenty of steering and has very little rear downforce/grip. Is this correct???
Any help or advice would be greatly appreciated.
Leonard.
Leonard.
Brant
#8207
Leonard.
Leonard.
#8209
Originally Posted by POOKYT
Leonard--First thing to do is lower the front roll center by 1 full shim or if thats too much steering then use 1 thick + 1 thin spacer. That will get your turn in. To get the mid corner speed up I went to the 6 deg. carriers. Try this stuff before you go changing bodies and stuff. I do like the Skoda body. But I think Mazda 6 and the Stratus 3.0 seem to have a little more turn in for me. Good Luck Man!!
Brant
Brant
#8211
Thanks for the info Brant. Much appreciated.
Brant
#8212
No problem man. And do what Rob said as well on the 41 tooth pulley if you have not already. The 41 on the spool is GOOD!!!!
Brant
Brant
Brant
#8213
At the Nats in Florida www.speedlinehobbies.com
19 Turn Qualifying complete
Matt #2 in going into the AAA mains
Modified Sedan
Billy #3 after 3 of 4 rounds
Matt #4 after 3 of 4 rounds
Modified Sedan
#8215
Originally Posted by Rob Phillips
a buddy of mine switched over to the JRXS this weekend and turned two laps more than his FK05. He's not the best of drivers, but it seemed to really help him.
#8216
Brant
Brant
Hey Brant,
With the Numan set up what shims should I be using, two of the thin ones or two of the thick ones that come with the kit???
Gareth
#8217
Leonard.
Leonard.
#8218
Originally Posted by Floss_LUC
Hey Brant,
Gareth
Gareth
Brant
#8219
finally, i hear of someone(s) doing better than they did before and they didnt get the x-ray! my track is filled with the x-ray sheep, even though our store barley carries enough parts for it. besides, if the xray is so good, why did they copy off of someone else? *cough**cough*tamiya*cough**cough*
