No rear end grip. >
No rear end grip.
Like Tree5Likes
No rear end grip.
Old 09-14-2017, 12:56 AM
  #16
Originally Posted by niznai
Said some great stuff
Thanks niz. That made a lot of sense. I shall try to put that into practice. Unfortunately I have no carpet I can test on lol.
Running 35s on front and 30s compound tyres on rear. I'm going to get some light oil today.
How's dose cst compare to weight as well? I have 400cst too
stuartkeith is offline
Old 09-14-2017, 07:11 AM
  #17
gigaplex's Avatar
It varies a lot depending on brand, but a crude approximation is that Xwt is rougly equal to X*10cst (400cst would be roughly 40wt, which is a decent starting point).
gigaplex is online now
Old 09-14-2017, 10:33 AM
  #18
DirkW's Avatar
IIRC that's only true for the lower weight oils, with higher weight, the spreads grows larger:
25~275
30 ~ 350
37.5 ~ 450
40 ~ 500
60 ~ 800
80 ~ 1100
DirkW is offline
Old 09-14-2017, 11:10 AM
  #19
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
kit setup
check all drive axles, outdrives, and make sure that all four wheels are powered equally
R3VoLuTiOn is offline
Old 09-14-2017, 04:27 PM
  #20
gigaplex's Avatar
25~275
30 ~ 350
37.5 ~ 450
40 ~ 500
60 ~ 800
80 ~ 1100
I did say crude
Old 09-14-2017, 11:38 PM
  #21
DirkW's Avatar
I did say crude
You did, I know.
But the factor changes from ~11 to ~14 on those examples I posted. - So I wouldn't even try calculating it with a fixed factor, personally. I usually look it up, if I need to.
DirkW is offline
Old 09-15-2017, 01:02 AM
  #22
I picked up some 25 and 30 weight oil yesterday. will start rebuilding the rear end tonight. the rear left shock seems to be leaking bad too, so need to replace the o rings. i have a spare car, so I'm sure I can sort.
On a steering note. how can I change the ackerman on the twin point steering upgrade?
Old 09-15-2017, 07:10 AM
  #23
ZEe_NYC's Avatar
Trader Rating: 78 (100%+)
Need-more-speed said it in the 2nd post. Rebuild your car. Something is tweaked. Just go over it again and make sure everything is spot on.
ZEe_NYC is offline
Old 09-17-2017, 04:49 AM
  #24
Right, I rebuilt the shocks last night and rear end. added the 4 notch camber plate and washers under. A whole lot better now. I can power on straight, and I managed to make it into the A final for the 1st time ever.
I came last though lol! But I have never been in an A final before. I had too many nerves and struggled to be smooth.
forFREEDOM likes this.
