Ask Chris Tosolini >
Ask Chris Tosolini
Ask Chris Tosolini
Old 04-14-2004, 04:39 AM
  #466
Default Spool
Chris,
When do you use :
-Spool (Carpet or asphalt / Wide or tight track)
-One Way ( """""""" )
Regards,
Hugo
Hugo is offline
Old 04-14-2004, 06:03 AM
  #467
Trader Rating: 17 (100%+)
i believe if i remember right he was the only one in the a main to run a spool at the novak race.
go toso!
Kave is offline
Old 04-14-2004, 10:32 PM
  #468
Default Re: Spool
Originally posted by Hugo
Chris,
When do you use :
Regards,
Hugo
I don't know what track, it is something you just have to test.
Chris Tosolini is offline
Old 04-15-2004, 09:15 AM
  #469
StephenSobottka's Avatar
Hey Drew,
Whats up dude!? U racing at RSJ on Saturday for that trophy race? I'll be there, I know Johnson and others will be too.
StephenSobottka is offline
Old 04-15-2004, 04:02 PM
  #470
Stephen whut up dude yeah I 'm coming see u there later Drew
Andrew Ellis is offline
Old 04-18-2004, 06:56 PM
  #471
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Chris-
I saw earlier in the thread that you use the LRP-QC2. I think seeing this has made up my mind, I've been racking my brain trying to decide between the QC2 & the GT-7. What's your 2 cents on the GT-7?
Also is that a Airtronics (#94758Z) servo? I have to look at that picture alot closer to see exactly what you did there. I just put my first kit together (it's the Yoke SD) and it's tight for electronics so here's what I'm planning on using:
Airtronics (94758Z) servo
Novak XXtra Syn. receiver (75Mhz)
LRP QC2 or GT-7 esc
Revolution V2 Touring motor (10x1) or Atsushi Hara edit. (10x1)
SMC, ProMatch, & Fukuyama batts (I want to compare all three)
Maybe you could let me know what you think of these electronics together, I'm TOTALLY green on this stuff (but I'm starting to lose my color )
It's GREAT to know that the main man for Yokomo has a thread.
WOW!!!!!
JayBee is offline
Old 04-18-2004, 07:08 PM
  #472
JayBee's Avatar
Oh I forgot, ANYONE can reply to this
YOKOMO: simply put-- THEE BEST!!
JayBee is offline
Old 04-21-2004, 06:43 PM
  #473
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Chris- Have you been able to get the CGM out on some larger paved tracks and rubber tires yet this spring? That season is just starting for us. Would love to know what you are running setup wise on asphalt!
Thanks again
Jeff
Jeff Werner is offline
Old 04-21-2004, 07:41 PM
  #474
first off to compare packs, take smc out the mix, and add huricane, then buy 2 times as many fukus as the rest of them because fukus > all
Kave is offline
Old 04-21-2004, 08:04 PM
  #475
eeyan's Avatar
Hey Chris... was wondering what motor you were using at La Mirada... it was ballistic on the straights!!! Were you using the spool from Speedtech as with the rest of the yokomo guys? Your car looked so hooked up last Sunday...
eeyan is offline
Old 04-21-2004, 10:14 PM
  #476
Originally posted by JayBee
Hey Chris-
LRP QC2 or GT-7 esc
WOW!!!!!
I try to use ant good fast and strong airtronic servos and gt7 is good and any small airtrinics reciever is good or novak.
Old 04-21-2004, 10:17 PM
  #477
I used my socal setup that I got working good last week and it was a one way..I used a 8double reedy kr in the main and a fuku 8 double in the qallifiers..
Old 04-21-2004, 10:29 PM
  #478
The Evicerator
TOSO!
Steve Weiss is online now
Old 04-22-2004, 12:45 AM
  #479
SCIDA's Avatar
Hey buddy what's up? We need to go back to the LIBRARY some time.
Chamberlain
SCIDA is offline
Old 04-22-2004, 12:47 AM
  #480
Josh Numan's Avatar
Trader Rating: 26 (100%+)
Wheres My Fuku 8 dub???????
Josh Numan is offline
