Shock shaft assembly tool
Anybody used one of this? Does it work?
I always use a piece of cloth w/ my pliers to attach the shock ends to the shaft. It is not bad, there should be something easier.
never seen that before..but i know rogue element (something like that) make some none scratch shock pliers which are supposed to be alright but i just use masking tape around the shaft and some pliers
Some rubber tubing around needle nose pliers should do the trick
