Tekno NB48.4 Thread >
Tekno NB48.4 Thread
Like Tree71Likes
Tekno NB48.4 Thread
    Hide Wikipost
Old 07-07-2017, 08:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48.4 Thread
Last edit by: MattDub
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Aluminum Servo Horn:
-TKR5251B (23T)
-TKR5252B (24T)
-TKR5253B (25T)
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (Rear)
This car is very durable. Here are the spare parts that we recommend you keep on hand:
Tips and Tricks
Vehicle Setup Adjustments and Build Tips
Tekno RC Instructional YouTube Video Playlist
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on our website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Setup Sheets:
Setup sheets for all of our vehicles can be found here.
What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Print Wikipost
Old 03-05-2019, 06:32 AM
  #286
HaulinBass's Avatar
Trader Rating: 16 (100%+)
i ordered two of the new lightweight wings, how have hey been holding up?
HaulinBass is offline
Old 03-06-2019, 07:33 AM
  #287
hairymuffin's Avatar
Trader Rating: 105 (100%+)
perfect, we put ours on the weekend of Dnc and no signs of distortion or wear, really happy they came out with the new wing.
hairymuffin is offline
Old 03-18-2019, 07:56 PM
  #288
HaulinBass's Avatar
awesome to hear. I was a little shocked how narrow the horizontal part was. looking forward to seeing how they run, could never bring myself to run lexan.
heres my soar rides with the new wing.
Old 05-07-2019, 06:16 PM
  #289
Default Nb48.4 toes help!!!
Hi i have build from grown up a mix of nb48.3 and .4,,so i have the .3 bell crank kit with steering rod on .4 arm,knuckle and c-hub,,,so it seem when i front check my wheel that they are to much toe out,,i have try the .4 steering link but was more bad than the .3 so if someone have a .4 and can tell me what toe it have from center tire to center tire would be appreciated!!!and any other info on build tip ,,you'r welcome.
kaven turcotte is offline
Old 05-13-2019, 08:04 PM
  #290
tobamiester's Avatar
Trader Rating: 360 (100%+)
Fairly sure you need the .4 Ackermann plate, and bell crank , when using the .4 rods.
tobamiester is offline
Old 05-18-2019, 06:18 AM
  #291
Hey guys i'm new from italy, this is my first nitro kit, i'm reading the manual but i don't get this
-RX battery, switch and harness
can you tell me what are you using on your nb48.4 kit so i can buy something similar?
thank you very much
grazie
elazo808 likes this.
pizelinho is offline
Old 05-22-2019, 06:15 PM
  #292
TAW
Trader Rating: 18 (100%+)
I use this one https://dialedhobbies.com/vp-pro-pow...-switch-detail
TAW is offline
Old 05-27-2019, 02:37 PM
  #293
Shady3275's Avatar
Has anyone else had trouble with breaking their diff out drives , this is on my nb48.3? I don’t even know how my rear suspension could have flexed to cause this to happen, I noticed it once I started taking car apart for cleaning after a few tanks of gas at the local track.
My concern is how I’m going to get the axle out of the diff outdrive, the pins in the axle are bigger than the hole it made in the outdrive ? Any thoughts on what could have caused this or things I should check before running again, these diffs have seemed to Be pretty bullet proof in my opinion
Shady3275 is offline
Old 05-27-2019, 04:51 PM
  #294
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
That's a pretty amazing thing to have happened, can't say I've ever seen that before. I would dremel the outdrive until you can get the bone out than just get a new set of outdrives, don't bother trying to save them. Send in the broken ones for %50 off a new set.
I can't think of how this would have happened other then some gnarly crash that first pooped the axle out, then smashed it through the thin part of the outdrive instead of popping back in.
Matthew_Armeni is offline
Old 06-13-2019, 04:33 AM
  #295
Hey guys its my first kit, i dont get why usin universal driveshaft instead of regular dogbones, whats the benefit?
Old 06-14-2019, 08:19 AM
  #296
Are you referring the to Universals versus CV joints, going to Hubs/Spindles ?
Old 06-14-2019, 10:05 AM
  #297
I mean part tkr5295/5296 instead of tkr 5377,whats the difference in performance usin one or the other?
Sorry for bad english, im italian
Old 06-17-2019, 06:50 AM
  #298
Universal driveshafts will smooth out front/rear power transfer and increase brake response by eliminating the fore/aft chatter of a dogbone center shaft system. the universal shaft will increase durability and consistency
Old 08-12-2019, 11:25 PM
  #299
Whats your radio tray set up please-any links or is a home built one ?
nitrorig is offline
Old 09-12-2019, 07:36 AM
  #300
boudin4evr's Avatar
https://blog.teknorc.com/2019/09/05/...-introduction/
Shady3275 likes this.
boudin4evr is offline
