Like Tree209Likes
Exotek F1R
Old 12-29-2011, 09:51 PM
  #151
Odin544's Avatar
Trader Rating: 93 (100%+)
Yes, there are inserts in the tires. Some of the pit tires come with really thin inserts. Others come with a thicker foam insert. I do glue the inner bead as well. Just didn't video that. It's pretty straight forward. Just learn to use less glue and it won't make a mess.
Any other questions, don't be afraid to ask!
Odin544 is offline
Old 12-30-2011, 09:01 PM
  #152
texastc's Avatar
F1R track report:
Car is awesome. Stock set up, 572s in the rear. I could not be happier. Thanks MikeR
texastc is offline
Old 12-31-2011, 09:48 AM
  #153
Trader Rating: 24 (100%+)
Thanks All for the reports and keeping the enthusiasm up. My new laydown servo setup is on the way so I can't wait to get my F1R up and running.
Aside from Exotek's site, does anyone have a suggestion for decent priced shorty packs ?
Evoracer is offline
Old 12-31-2011, 11:23 AM
  #154
MikeR's Avatar
Trader Rating: 15 (100%+)
Promatch Racing
The Losi packs are down to $79.95 on some shops if you want to keep the 'blue' color theme going.
MikeR is offline
Old 12-31-2011, 12:35 PM
  #155
texastc's Avatar
TQ carries the CRC but they are out. Also on my list.
OK, I may have done a bad thing. I confess. But I really like the older bodies, so I fit my MP4/6 on my F1R. And I like it.
texastc is offline
Old 12-31-2011, 08:36 PM
  #156
Odin544's Avatar
Originally Posted by MikeR
Promatch Racing
The reedy shorty is also $79. That's what I've been using.
Odin544 is offline
Old 12-31-2011, 10:40 PM
  #157
Odin544's Avatar
We added carpet to our track and changed the layout slightly. So our track is a little more open and flowing. Tried the F1R out as well as my F104 pro. The pro was about .5 seconds per lap faster consistently. I ended up running the Pro for the mains.
The F1R seemed really loose in the rear. The rear wanted to slide out entering the turns and diff out under power. Just wasn't as planted as the pro was. I'm running the kit setup on the F1R. I also tried pit 574 and 575. They felt like they had a little more grip. But still not enough in the rear.
I plan on trying the lay down servo mount which will add a little more weight towards the rear. But I'm thinking of trying the larger lipo as well.
Odin544 is offline
Old 01-01-2012, 04:09 AM
  #158
JamesHealey's Avatar
You're not alone I'm in the process of painting up a Jordan 191.. for a EXO104 Narrow car.
JamesHealey is offline
Old 01-02-2012, 07:36 AM
  #159
avs
avs's Avatar
Sorry, i know that there has been a lot of shimizu tire discussion already, but...
There has been a lot of people suggesting the 571/572 front/rear combination. However, the F1R tuning notes indicate 574 or 577 for front.
The designations seem to be a F1 vs F3 compound? and soft or medium insert or sidewall. 571,573 are F1 soft/medium while 574/577 are F3 soft/medium/
So my question is how does the 571 compare to the 574 or 577? I tried the 571 and found it very sensitive to traction additive. (SXT on carpet) With full tire treatment it traction rolled all over, while 1/2 tire treatment produced severe understeer.
Does the F3 family behave like the F1 or are they less sensitive? Thanks for any insight.
avs is offline
Old 01-02-2012, 02:27 PM
  #160
robk's Avatar
Trader Rating: 22 (100%+)
I only run the 574, and it seems to maybe have more grip than the 571.
I'm not sure about the letter/number designations...
One thing i have had a thought on was the sidewall tears that happen at times. I think it happens because the rim has a sharp 90* transition from the tread area to the sidewall. I think if the sharp edge was dremeled or sanded down to a curved transition, the tearing would stop.
robk is offline
Old 01-02-2012, 08:44 PM
  #161
texastc's Avatar
Who makes the side dampener for the F1R? Numbnuts here busted part of it dismounting it. Now I need parts.
Or another option.
texastc is offline
Old 01-02-2012, 08:49 PM
  #162
Odin544's Avatar
AE 12r5
Odin544 is offline
Old 01-02-2012, 09:00 PM
  #163
texastc's Avatar
Originally Posted by Odin544
AE 12r5
your the man! thanks
texastc is offline
Old 01-02-2012, 09:08 PM
  #164
Odin544's Avatar
Forgot to mention that the side links, side springs, pivot balls, spring retainers, and rear pod center pivot are all from the 12r5. Makes getting spares easy as most hobbyshops stock AE stuff.
Odin544 is offline
Old 01-02-2012, 09:15 PM
  #165
texastc's Avatar
Yeah, that will make it easy, if its one thing my LHS has its AE parts.
texastc is offline
