good soldering iron? >
Old 09-08-2007, 12:31 PM
  #16
Tommy Bergfeldt's Avatar
The Hakko 936, does it take 110-230VAC? I'm thinking about getting one when i'm over for IIC, but will it work here at home with 230V?
Tommy Bergfeldt is offline
Old 09-08-2007, 06:07 PM
  #17
BSchorr's Avatar
Trader Rating: 101 (100%+)
Originally Posted by P2
Here's a pic...as you can see, no 3 lb control unit!!
Did that come with that nifty stand to?
BSchorr is offline
Old 09-08-2007, 06:12 PM
  #18
BSchorr's Avatar
nm, i see they have teh stand seperate
BSchorr is offline
Old 09-09-2007, 01:26 AM
  #19
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Yes I have had my Hakko 936 station for like 2 years. It is well worth the $$ cost. I would recommend that.
BuggyKing is offline
Old 09-09-2007, 11:06 AM
  #20
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
So you guys dont think a soldering iron with the unit is very good?
That hakko all in one looks nice!
What would be the wattage on it?
BlackedOutREVO is offline
Old 09-09-2007, 11:42 AM
  #21
Trader Rating: 88 (100%+)
anyone got a part number for the tip used to solder batts together and also a site that has them in stock....
joey is offline
Old 09-09-2007, 07:20 PM
  #22
P2
P2's Avatar
Trader Rating: 15 (100%+)
That "all in one" unit is not a Hakko...it's a Goot (made in Japan). I switched from Hakko to Goot and saved 3lbs of weight/pit space and no performance difference.
You can find Goots at www.bomir.com
P2 is offline
Old 09-09-2007, 07:22 PM
  #23
Ohhhh..... Ok
it looks nice
Old 09-09-2007, 07:23 PM
  #24
P2
P2's Avatar
Here you go for the Hakko:
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
I think you need the high capacity 908 tip for the large tip.
P2 is offline
Old 09-09-2007, 07:29 PM
  #25
https://www.ssl-stormerhobbies.com/c...s&pn=HAKP93613
That looks nice! Thats what everyone at my local track uses
So the 908 will be able to run all the iron's?
Theres too many things to choose from lol
Old 09-09-2007, 07:35 PM
  #26
P2
P2's Avatar
Everyone at my track uses Hakkos too, I used one for 3+ years. I just wanted to cary less weight. EJ Evans and I shared my Goot at the Nat's in Seattle and had no issues, same thing for the upcoming IIC.
I used to live in Japan and everyone uses Goot irons
P2 is offline
Old 09-09-2007, 07:37 PM
  #27
Your in my area, I know who EJ is
Where do you live?
IDK, weight, space isnt a issue for me (YET)
Old 09-09-2007, 08:12 PM
  #28
CarlosG.'s Avatar
Trader Rating: 12 (100%+)
P2 in TX.
CarlosG. is offline
Old 09-09-2007, 09:29 PM
  #29
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Here's one I saw today at the track. Didn't get a chance to try it out.
http://www.hakko.com/english/products/hakko_presto.html
minicooper is offline
Old 09-09-2007, 10:28 PM
  #30
odpurple's Avatar
Originally Posted by aus jd 2703
hey guys looking for a good temp adjustable iron that'll last me for every not really on a tight budget if it last want some thing i can do circuit board work with i have an iron dedicated to battery building now need a versatile iron for everything else.
cheers
josh p
ps what iron is the one RCID do a skin for?
The Hakko 936 is a good choice, but if you want to do good work on cirquit boards you wll want a small tip, like 2mm. You can get two irons for the station and switch them but the best way to go is the Hakko 928 dual soldering station. Then you can have a large handle and tip that will work for everything but batteries, and the teenie tip for cirquit board work. You can solder batteries with the 928 but its better done with a 456. 455 works great too but the 456 shows no mercy
odpurple is offline
