Engine run in stand
search the internet for nanda.
rd logics is the same exact one as nanda except it's more expensive because of the name.
you will need a remote starter like the ones used for airplanes.
nanda is about $60-70, plus starter is about $25-35
the hudy/serpent is nice also but very pricey!
If you live in Sothern Ca. area, you can get the RDLogic one at Ultimate Hobbies for $99
We have Nanda engine break in stand on specials!
http://www.rc-toro.com/product_info....79d6baf81d1f1a
Has anyone used the 75 dollar stand yet? just wondering on the quality of it.
it's very nice, the only thing I didn't like is tha fuel tank, at the end of the tank the higher pressure forces the cap causing fuel leak.........
anyway it works, maybe with harder spring ou another o-ring the sealing will be better........
The Nanda engine break in stand is good. Just buy a airplane 400+cc fuel tank. it is very cheap and big.
I too was looking at an engine break in stand. I was curious about the prop to attatch it to an engine. I looked at a stand this week and it didn't have instructions on "how to" attatch the prop.......If it is suppose to be common knowledge, I'm just not common
I don't use the propeller that comes with the stand.........
I use plastic 7x4 (.21) or 6x4 (smaller engines) with novarossi adapter.........
BTW>>>> I solved the fuel tank cap issue by bending the spring........no more fuel leak now.....
