Hobbywing ESC Settings ONLY
#256
Hello,
I just received two 1S HW 120A ESC.
Any help of settings on a 12th scale with a 10.5 with zero timing (blinky)? It's for an indoor carpet track that is small and technical. Here is a vid:
https://www.youtube.com/watch?v=6d4A7e1w9Xc
For now I didn't upgrade any software or anything.
Basic Tab
Run mode: Fwd Only w/Brake
Drag Brake: 0%
Low Voltage Cut: Disabled
DDRS Start Mode: 9 (great punch and fast race starts)
Max Brake Force: 100% (Blinky brakes are weak)
Advance Tab
Max Reverse Force: 100% (Related to brakes, high numbers hear increase brake strength)
Initial Brake Force: 0%
Heat Protection: Disabled (This disables the motor heat sensor)
#257
You have to update the ESC firmware to "No Timing 508_V3" to get blinky mode. There are just a few settings for blinky.
Basic Tab
Drag Brake: 0%
Advance Tab
Basic Tab
Drag Brake: 0%
Advance Tab
#258
Hi guys,, this is my 1st post
I use ESC 120A V2.1,, already update to V3.0 Stock,, Turbo and Boost is open,,
My question,, can I use firmware 3.1 into ESC 120A V2.1 ??
coz V3.1 setting is more detail
any info please...
thx before
sorry my english is bad
any info please...
thx before
#260
If I understand your question correctly .. the answer is NO.
1. The picture on the left shows the options for the V2 line of ESC's.
2. The picture on the right shows the options for the V3 line of ESC's.
You can't get the software options of the V3 onto the V2 via software.
#261
This is from the hobbywing website:
Hobbywing USB Link Software V3.2
Software Versions
Version 3.2_121204
The Version 3.2 is suitable for the following ESC:
XERUN Series*Car*ESC (Version 2.0/2.1/3.0/3.1*and later)
EZRUN Series* Car ESC (Version 2.0*and later)
PLATINUM Series helicopter/airplane ESC
#263
Im pretty sure hes asking if he can use the V3.2 USB software on the v2.1 ESC which you can.
Software Versions
Version 3.2_121204
Software Versions
Version 3.2_121204
He is already using V3.2 USB Link from the pics he has .. look at the window title.
I believe he is asking if the "more detailed" software can be used on the V2.
The "more detailed" software is strictly for the V3.
The pic on the left is what you see when you connect a V2 to the PC.
The pic on the right is what you see when you connect a V3 to the PC.
The V3 has more options.
#264
I already use V3.2 USBLINK from web....
so it's mean v2.1 and v3.1 is different hardware ??
when i connect my esc to program box it show v3.0 stock
hopeless I can use setting v3.1 at my v2.1
my attachment show database for v2.1
#265
Correct. The V2/V2.1 and the V3/V3.1 use different hardware.
Correct .. some of the software for the V2 ESC has the name v3.0_xxx. It is a little confusing to some.
You cannot .. those settings are for the V3 ESC, firmware v1.11_xxx which you cannot load onto a V2 ESC. You will only have that option in your Database if you connect a V3 ESC.
None of the software in that Database will give you the settings that a V3 ESC has. The V3/V3.1 ESC has more options and that is why some people buy it.
#266
Titc v3 setup
Hi guys...
I'll be going to race using v3 this February in titc rc addict on open brushless
Do you guys have a good setup for the v3 esc...I'm using 13,5 motor...
#267
hope next firmware from HW give ESC v2 more detail setting even though not like V3.1....
by the way,, can u give some advice which firmware best for esc v2,, i used it for drift at carpet
#268
#269
Basic Tab
Drag Brake: 0%
Advance Tab
Basic Tab
Drag Brake: 0%
Advance Tab
Now I need to choose a setting to start with considering I have the firmware v3.2 with access to all the settings
