Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 01-29-2010, 03:57 AM
  #18406
gixer's Avatar
I have the chance to swap a spare set of me Aluminium Cyclone dampers for a set of Tamiya TRF dampers.
They physically look about the same size, but how do the Tamiya TRF dampers compare i use please?
Cheers
Mark
gixer is offline
Old 01-29-2010, 04:21 AM
  #18407
decibels's Avatar
Cheers
Mark
They are pretty much the same!! I actually use the 3 hole tamiya pistons in my shocks because i have tamiya ones as well and they are just a copy!!
decibels is offline
Old 01-29-2010, 07:21 AM
  #18408
jag88's Avatar
Can anybody (Korey, Hiro ?) tell us anything about Baker's car as far as chassis (Exotek ?), set up, any mod's etc. ?
Is this a spec tire race ?
Thanks.
jag88 is offline
Old 01-29-2010, 08:24 AM
  #18409
Originally Posted by Korey Harbke
Zero rebound . I don't run the bladder foam, and I drilled a small hole in the shock cap to relieve pressure on top of the bladder.
-Korey
korey im having touble finding losi 37.5 oil in the uk , i have some schumacher 35wt and 45wt , which of these should i go for on your setup
thanks again
madwestmo is offline
Old 01-29-2010, 10:05 AM
  #18410
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
I'd go a bit thicker than what I was running. I'm finding that a bit thicker worked out a bit better overall at more tracks. So try the 45wt
-Korey
Korey Harbke is offline
Old 01-29-2010, 10:18 AM
  #18411
Thanks.
I saw a few pictures, it's pretty much a basic car. He's running the front suspension block modification (didn't see which block), std chassis (non exotek), but he is running a TOP battery retainer setup. Its basically a car very similar to what he ran at the KO GP it seems in terms of hardware.
-Korey
Old 01-29-2010, 12:25 PM
  #18412
tc3 racer sc's Avatar
Originally Posted by ShaunMac
Sounds like you need some TEKIN.
thxs ur right may get one soon lol car a little better today add more timing on motor
tc3 racer sc is offline
Old 01-30-2010, 04:55 PM
  #18413
Luppi Stefano's Avatar
wow guys!
ETS prostock qualification:
1. Wohlgemuth Daniel (DE) - 310pts (Hot Bodies)
2. Stocker Alexander (DE) - 308pts (Hot Bodies)
4. Rajka Balint (HU) - 304pts (Hot Bodies)
ETS modified qualification:
4. Andy Moore (GB) - 305pts (Hot Bodies / Team Orion)
Not bad!
I'm confident for the Finals on Sunday!
Luppi Stefano is offline
Old 01-31-2010, 03:37 AM
  #18414
Iceman 69's Avatar
Hi Gents,
maybe the cyclone guru's can help, our club here recently introduced the 10.5 rubber class, i run a TC with a LRP shere and a novak 10.5, the probelm is the rear of the car keeps breaking away on power - what could be wrong?
any assistance is much appreciated
Iceman 69 is offline
Old 01-31-2010, 04:00 AM
  #18415
AGNO's Avatar
Originally Posted by Iceman 69
Hi Gents,
Carpet or asphalt?
AGNO is offline
Old 01-31-2010, 04:11 AM
  #18416
Iceman 69's Avatar
sorry mate, its outdoor asphalt, med grip
Old 01-31-2010, 04:18 AM
  #18417
AGNO's Avatar
This Seup is for 17.5 but it works very well with 10.5.
AGNO is offline
Old 01-31-2010, 04:31 AM
  #18418
Iceman 69's Avatar
thanks dude, just 1 question the springs are they HPI or team associated?
Old 01-31-2010, 09:29 AM
  #18419
AGNO's Avatar
HPI
AGNO is offline
Old 01-31-2010, 09:40 AM
  #18420
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
you also could have too much caster not enough rear toe or to stiff of springs. or not enough droop.
TRXRACER99 is offline
