Mugen MTX-3
Old 01-18-2003, 09:51 PM
  #1696
Manticore's Avatar
again...
Manticore is offline
Old 01-18-2003, 09:52 PM
  #1697
Manticore's Avatar
more..
  #1698
Manticore's Avatar
more and more
Old 01-18-2003, 09:53 PM
  #1699
Manticore's Avatar
some more
Old 01-18-2003, 09:54 PM
  #1700
Manticore's Avatar
some more 1
Old 01-18-2003, 09:55 PM
  #1701
Manticore's Avatar
some more 2
  #1702
Trader Rating: 2 (75%+)
Lightbulb
oohh, oohh,oooh.......can i play here!!?!?
Matincore, I also read your posts and i think you were the RUDE one here too!
Being a Serpent driver/owner I can have all the confidence that the new 705 will speak for its self!!
PUNISHER is offline
Old 01-18-2003, 09:56 PM
  #1703
Manticore's Avatar
some more 3
Old 01-18-2003, 09:57 PM
  #1704
Manticore's Avatar
Matincore, I also read your posts and think you were the RUDE one here too!
i do how you feel punisher!! sorry that you are one of the snake owner ! but not for initiald!!
Old 01-18-2003, 09:58 PM
  #1705
Manticore's Avatar
last
Old 01-18-2003, 10:00 PM
  #1706
Jack's Avatar
I am still driving my V1RR, and my serpents.
V1R do not have any overdrive if i remember correctly but the RR does..
let the guys here post about their stuff and their findings
and let not tread into their space.
anyway i read about you posting about Kyosho Drivers using serpent 2speed.... That is not possible at all......someone is pulling your leg on this
Jack is offline
Old 01-18-2003, 10:28 PM
  #1707
AMGRacer's Avatar
Originally posted by InitialD
AMGRacer, can I know how you arrived at such overdrive figures of the V1RR with 27T side pulley?
Front drive ratio = 32T / 18T x 27T / 19T = 2.5263
Rear drive ratio = 48T / 19T = 2.5263
Both front and rear drive ratio is exactly the same. Assuming both front and rear tires are equal in diameter (which they are if you buy them stock), how does that make 0.5 to 0.9% overdrive?
Hmmmm you are right. I did this calculation more than a year ago and found a front overdrive. I must have miscounted some pulley teeth
AMGRacer is offline
Old 01-18-2003, 11:31 PM
  #1708
Nitro Tech
dino.tw's Avatar
Wink ODR tool
download this tool,you will need it.
http://www.stsrc.com.tw/info/ratio.zip
1)download and unzip it.
2)calculate the teeth of the pulleys and edit the table.
3)than press the [SAVE] button.
Well,you can start to calculate the gear ratio for your 3-belts drive R/C cars.
dino.tw is offline
Old 01-18-2003, 11:33 PM
  #1709
Manticore's Avatar
Default Re: ODR tool
I have this tool for a while and do like it much ! do you have a palm version so that we may do it at the track?
Old 01-18-2003, 11:51 PM
  #1710
Nitro Tech
dino.tw's Avatar
I wrote it several years ago,when i still a newbie.I used Delphi to create it.Maybe i should do another JAVA version.
But!Do you have time when you stay at the track?Don't lie to me.The playing time is already not enough,how can you take out your Palm?Haha....It's a joke....
dino.tw is offline
