3racing F109
#856
Trader Rating: 25 (100%+)
Thanks--- a long way to ship springs--but I got em coming!!!
T
T
#857
Here's a scanned copy - I made a note about the "adjustment nut". Mount it almost flush with the threads and tighten the diff with the 4mm lock nut until it feels OK (as close as you can). Then use the adjustment ring for fine tuning at the track.
#858
And thanks for the heads up on the adjustment nut
#859
I just bought a used one of these and was wondering if anyone has a set up sheet for it or know a web site where I can get one?
I found one for the f104 but it's not quite the same
Also, I have never run a pan car before and was wondering if there is any site that will explain how different oil and springs will affect the handling characteristics without a lot of trial and error.
Any help will be greatly appreciated.
#860
i have some modify.
use 2 26mm metal post instead of original upper deck post(plastic).
charge a battery like F104.
#861
#862
Hey thanks Robk that is just the thing I was looking for.
Now for a set up sheet!
#863
Rear Links
ROBK,
Are you guys using the standard turnbuckles or replacing them with a longer aftermarket set?
I am new to the F1 and have been reading this thread for insights. I noticed a suggestion to use the forward hole for mounting the rear links. I tried this on the weekend but one side keeps letting go.
I did pull them appart completely to ensure I had an even amount of insertion at both ends of the rods.
I hve run the F109 a few times and have had difficulty keeping the tail under control. I have picked up some stiffer side springs and will try them next run.
I also had the unusual circumstance of the centre rolling damper coming undone during a run. Silicone is NOT good for traction.
#865
ROBK,
#866
ROBK,
1. Stiffer Side Springs on the Rear
2. Toe Out 1 Degree
3. Switch to 2 Hole Roling Damper and Main Damper, Change oil to 50wt
4. Change to Stiffer Front Springs
and so far its handing a lot better than the beginning
note, if you are running on asphalt track be sure to use rubber tires, you get a lot more grip.
Funny, i also found that my rolling damper just jumped out during a pratice session. might be because of a little bump on the apex.
#867
Rear Links
robk/ADHUI,
Thanks for the info guys. I will get some longer links and try again.
My centre damper stayed in place, it's just the darn thing actually came apart and spilled silicone damper fluid all over the place - what a mess!!
I had changed the three hole psiton to 1 hole and put some XRay 40w damper fluid in to try and slow the movement in the rear a little. Hopefully the springs I picked up today will assist.
Thanks again.
Thanks again.
#870
Hi guys,
first of all i did not read the hole thread.
shame over me.
now i have some questions perhaps you can help.
im now an owner of this car.
i have read that the front end of the f-103 will fit. is that correct?
because i want to try out the upper arms of the f-103.
would you recommend that or is it better to stay with the original front end?
i found a gpm upper arm set for the f-103.
see the pic, will this fit?
also i want to install the Adjustable Front Castor Mount Version 2.
is this possible to fit this with the gpm upper arms or do this castor mount would only fit with the f-109 upper arms?
and how can i adjust the front ride hight?
thanks for answers.
shame over me.
thanks for answers.
