Team Losi JRXS Type-R >
Like Tree52Likes
Old 10-07-2008, 09:55 AM
  #8206
MikeXray's Avatar
Trader Rating: 73 (100%+)
Here they are
Attached Thumbnails Team Losi JRXS Type-R-reedy-setup.jpg   Team Losi JRXS Type-R-schreff-jackson.jpg   Team Losi JRXS Type-R-jrxs-type-r-rubber-iic-2008.gif
MikeXray is offline
Old 10-07-2008, 10:05 AM
  #8207
metalracer2's Avatar
Trader Rating: 20 (100%+)
i will never buy a new set of RP 30's i have two sets of the old rp 30's left.
mike thanks for finding the setup sheets for me
metalracer2 is offline
Old 10-07-2008, 03:03 PM
  #8208
Trips's Avatar
Trader Rating: 16 (100%+)
Just thought I'd post a quick heads-up here...
A few pages back in this thread I asked if anyone knew of a PDF reader that would allow us to change the setup sheets and save the changes... Adobe reader doesn't save changes, and their Acrobat software is a bit pricey at $299... Mike Haynes made the suggestion to fill in the form using Adobe Reader, and then using the snapshot tool to save the completed setup sheet as a "gif" file. That works, but it's tedious to edit the gif if you make minor changes...
I've found a freeware pdf reader called Foxit reader which allows you to make changes to the pdf forms and save and/or print the changes. I downloaded it from Tucows...http://www.tucows.com
Just wanted to mention it here in case it could be useful for anyone else.
Trips is offline
Old 10-07-2008, 08:23 PM
  #8209
adamge's Avatar
Trips, foxit reader is my preferred pdf reader. Direct link to their site:
http://www.foxitsoftware.com/
When you save the alterred sheet, does it put red text saying 'trial version' on the sheet?
adamge is offline
Old 10-07-2008, 09:29 PM
  #8210
cclifton's Avatar
Trader Rating: 13 (100%+)
Default Gearing Question
Hi there,
What is everyone running for gearing with a 17.5 and rubber tires. All the reading I have been doing people are usually running 3-4 FDR. This looks to be a possible issue unless someone has a suggestion. The largest pinion I can get locally is a 47 and the smallest spur I have seen for the losi is a 118 which only give a FDR of 4.59. Any suggestions?
Chris
cclifton is offline
Old 10-07-2008, 10:13 PM
  #8211
Originally Posted by cclifton
Hi there,
Chris
yeah get the prs spur adapter to run a smaller spur i use a 104 and a pinion in the mid 50's
http://www.precisionracingsystems.com/products/18
  #8212
I just started running 17.5 rubber. I'm used to running 13.5 foam. I'm running a 4.2 fdr on our track. 66x43 carpet track. Running 112/48 to get the ratio. Using a prs spur gear and the prs adapter.
JoelV is offline
Old 10-07-2008, 10:38 PM
  #8213
RedRocketRacing's Avatar
what are guys running for fans? The book say 20 x 20. Where are people finding them? Need some info asap. Need to get some ordered.
RedRocket
RedRocketRacing is offline
Old 10-07-2008, 11:04 PM
  #8214
Matt Howard's Avatar
RedRocket
AE used to sell a fan kit for their TC4, I used those fans since they were already wired up with a connector and ready to go
Matt Howard is offline
Old 10-07-2008, 11:08 PM
  #8215
Do you know if they were 20x20's or 25x25's? Thanks for the tip Matt.
RedRocket
Old 10-07-2008, 11:14 PM
  #8216
RedRocket
I don't know what the size was but they are the "right" size (they screw into the bulkheads fine)
Old 10-08-2008, 05:57 AM
  #8217
Mike Haynes's Avatar
25mm is the right size, the novak, much more, or speed passion (25mm) fit right on.
Mike Haynes is offline
Old 10-08-2008, 06:57 AM
  #8218
Brazilct's Avatar
whats up mike H ? save me a spot for Sunday if you don't mine
Brazilct is offline
Old 10-08-2008, 07:27 AM
  #8219
Trips's Avatar
No, I didn't notice anything like that...
Trips is offline
Old 10-08-2008, 01:07 PM
  #8220
racingboy14's Avatar
Trader Rating: 25 (96%+)
does anyone know what a good gear ratio is for a 17.5 with foam tires on a high bite track. I was told to gear it around 4.2-4.6 fdr but i dont really know how to calculate that.
racingboy14 is offline
