Tamiya TB-Evolution III
#4096
Re: Where can we buy it?Please let me know if you know where.I am desperate now!
Originally posted by racenut123
#4097
Hey hierog,
I got all my square parts from Niki's hobbys in HK, Msg me if you need his email address.
#4099
If the pinion gear stripping internally - please replace the driveshaft and the front gear box cover. Make sure the gear box cover can hold tightening the front one way. If not, it will causing the pinion gear can't fully press into the driveshaft and let it stripping internally. I hope my opinion can help all tb3 owner.
#4100
Re: Re: Tech Center shaft
Originally posted by Randman
Hmm, looks like it would work well, I'm guessing that bearing in there is for the front block between the steering posts...
#4101
rick i fought you was getting an sd?
#4104
Any word on where to buy the Tech shaft?
#4105
rainbow ten
#4106
Re: Re: Where can we buy it?Please let me know if you know where.I am desperate now!
Originally posted by audiaudi
I may have it in stock. let me check.
#4107
Originally posted by Rick Draper
The part number is EV0031 and if someone will resize the pics of my car then upload them people will be able to see it on my car. Rick
#4108
Re: Re: Re: Tech Center shaft
Yes the bearing sits in the plastic block inbetween the steering posts. Rick
#4109
Super Moderator
Gear Saver
Hey guys. I figured out the cheapest way to fix the stripping gear problem. Strengthening the gear! After 2 months of weekend racing and many crashes, the gear held up. This is not a Tamiya Legal part, but seems to hold up VERY well! I gave Penguin RC the Specs and made it the same day! The Disc is notched inside to match the gear's mold.
He will probably go in production on this part very soon I think it will go for about the $6-$10 range. I am not sure..it is really up to him.
#4110
Re: bulkhead or ring gear ?
Originally posted by Roger
Is it the drivetrain, bulkhead, or the front one-way ring gear that's causing the gear to strip due to impacts. I've seen numerous modifications on front one-ways fail. Have you ever thought that it's not the front one-way, but maybe the whole drive train system ?? True, its fast just like other shaft driven cars, but why is it just this car ? How come the TC3 or the yokomo SD don't have problems like the evo3 ?
Rog
The problem is with the way Tamiya made the center shaft system. All shaft drive cars need to have the shaft float so any slight misalignment between it and the gearboxes and any chassis flex won't make the whole drivetrain bind up. The difference between the Tamiya setup and the TC3/SD is that the others use a 3 piece shaft system. On the TC3/SD, the front and rear pinions are mounted on fixed stub shafts and the bearings are tight in the gearboxes. This allows for consistent, correct gear mesh between the ring and pinion gears. The center shaft being a big dogbone sitting in drive cups still floats.
Tamiya's setup is a single shaft and it floats by sliding in and out of the pinion gear (That's why racenut123's stripping the "D" out in the pinion) and the slop between the pinion bearings and the holes they sit in in the gearbox cases. The system floats by the slop.
If you wiggle the EVO 3 center shaft, you'll notice the front has more up/down, side/side play than the back because of the lack of the extra bearing that the rear (in the motormount) has. This makes the front gear mesh really inconsistent and poor. Add to the fact that the front uses a 1 way with no give (diff action) you'll strip gears. You can add a bearing in the front plastic support but I think Tamiya left it out so the drivetrain would be less likely to bind up ie. have more slop.
I don't know why Tamiya did this. Their nitro cars like the TGX is shaft driven yet has a 3 piece system just like the TC3/SD. Why did Tamiya go to a 1 piece drive shaft system on the EVO 3.
Now you, racenut123 and aurra sing know why I have not driven my EVO 3. I need to fix this first. I saw someone convert to a 3 piece system using SD parts or I was going to look into using the Tamiya nitro car's pieces but the Tech Racing 3 piece shaft kit looks good.
