Losi Street weapon >
Losi Street weapon
Losi Street weapon
Old 12-17-2004, 02:49 AM
Default Losi Street weapon
Hey ppl,
i recently started rc racing nd bought a 2nd hand street weapon iwc edition.
Dus an1 have any insight of tips on the car for me
help wuld b appreciated
thanks
Losi-sw
losi-sw is offline
Old 12-17-2004, 03:32 AM
Default plz
plz any1???
losi-sw is offline
Old 12-17-2004, 03:41 AM
Lonestar's Avatar
Trader Rating: 14 (100%+)
buy LOTS of extra front wheel bearings... seriously
Besides that, I loved the car. it rocked in mod, a little slow in stock due to the inefficient tranny though. Like the XXXS, some folks gave it a bad rep (the "shelf weapon"), but the car still won a ton of races (Josh Cyrul took the roar nats with it if I remember right).
Cheers,
Paul
Lonestar is offline
Old 12-17-2004, 03:47 AM
Default still alive
do u think it would b able 2 cope wid da competition 2day?
thanks
losi-sw is offline
Old 12-17-2004, 04:14 AM
razzo's Avatar
no offense, but you might get better responses if you actually tried to spell correct english....
razzo is offline
Old 12-17-2004, 04:51 AM
Default sorry
im very sorry.....i just felt shortening the words made for quick messaging. But it seems like people have a problem with it.
losi-sw is offline
Old 12-17-2004, 07:20 AM
Cain's Avatar
Trader Rating: 294 (100%+)
I would pickup several of these vehicles if you can from a parts perspective.
You may also want the RPM kit that lets you use standard wheels on the SW. Only thing is that it widens the car to 200mm. So depending on how strict the track is where you race it may be illegal.
Cain is offline
Old 12-17-2004, 07:23 AM
ground-round's Avatar
Trader Rating: 22 (96%+)
I think the lack of response isn't because of your typing, its because most of the people on this board weren't even racing when the Street Weapon was popular. I bought one when they first came out...back in '97 or so. I could never get it to be competitive. Of course that was back before you could compare setups on the Internet. The only setup help I had was one other guy at my track that ran one. We both sold them after about a year. Probably not a bad car if you can find a setup for it. However, I must ask...why not get a used car that you can still get parts for? You can get a used TC3 on Ebay for $75.
ground-round is offline
Old 12-17-2004, 07:25 AM
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i have a sw with the cyrul conversion.....you can own it if you would like.....50 bucks...
Matt M. is offline
Old 12-17-2004, 09:31 AM
DrOlds's Avatar
The IWC Street Weapon is a perfectly good car to get started and have fun with at the local level.Parts are not a problem-everything is still available and you can buy used whole cars for parts dirt cheap.(That Cyrul conversion car is a deal-you should buy it).There are several setup sheets for them on the Team Losi website.You didn't say whether you are running foam or rubber tires but just go off the setup sheet that is closest to what you run and you will have a very good starting point.With just a little tuning you can make the car very easy to drive and have a blast.I have used the RPM kit to convert to common hex drives but the easy way to do it is to put XXXS cvd's in the front and TC3 drive hexes front and rear.If your car already has cvd's you only need the front axles and bearings.The standard setup is hard on the front bearings.
And yes the proper english is appreciated.
DrOlds is offline
Old 12-17-2004, 09:38 AM
at the club i race at we have to use M1's T27 tires. I'll be racing in the stock class as i this is my first time racingg!.
losi-sw is offline
Old 12-17-2004, 10:04 AM
DrOlds's Avatar
http://www.teamlosi.com/pictures/jpe...etstd_todd.jpg
I used this setup for rubber tires on carpet with these changes-
-black springs front and rear
-no sway bars
-no shims under pivot support
I just raised the front ride height a little at a time until it was balanced with traction compound all the way across the tires both front and rear.Good luck-have fun!
DrOlds is offline
Old 12-17-2004, 10:13 AM
thanks droids.....your help is very much appreciated. about making my wheel hexes universal......did u say i should use associated ones?
thanks
losi-sw is offline
Old 12-17-2004, 10:16 AM
DrOlds's Avatar
You can use Associated TC3 or Losi xxxs hexes.
DrOlds is offline
Old 12-17-2004, 10:18 AM
and do i just buy them from any model shop? or do i have to order them?
losi-sw is offline
