Tekno SCT410 BCE V2 Chassis
FS: Tekno SCT410 BCE V2 Chassis
SOLD
This truck had a refresh just before I put it on the shelf, arms recently replaced just because and reamed. I have about 10 race days on the BCE chassis, had just swapped from the V1 BCE to V2. Transponder power lead routed up front and sitting on servo. Current setup is for high bite clay but there are shock spring and piston combos to suite any track or driving style. If you happen to run on Clay, throw it on the track and enjoy. Same with pinions, anywhere from high speed outdoor to small indoor tracks are covered. There are several spares, some new, some just replaced with new and kept as backup.
Fioroni pistons are incredible, really keeps the rubber on the dirt compared to a traditional piston. Not cheap but hey... they are in the truck, you might as well try them out!
Between the BCE chassis, Lunsford links, Mugen Ti screws and only adding aluminum hop-ups where needed, this is a very light Tekno with crazy amounts of traction. 5 lb, 10 oz RTR, no lipo. The BCE chassis is a fantastic upgrade which hasn’t been available for years now. I didn’t add a carbon tower to the rear to keep as much weight in the back as I could, this fly’s very neutral, I did not have any issues with nose down flight.
The Ti screw kit is not some junk eBay kit, they are top quality Mugen screws and every screw that’s not under a major load (F/R diff underside screws, camber links, shock posts etc.) or is a specialty screw has been Mugenized. There are several spares as well.
Includes Team Associated DS 1015 Digital Servo currently in the truck.
To sweeten the deal, I am throwing in a RX8 Gen2 that I think needs a Cap or something. Shouldn’t cost much to send back to Tekin and end up with a $200 ESC on the cheap
Parts list:
Parts list:
- BCE V2 Chassis with standard/rear battery placement, 1mm lower CG than Tekno chassis
- ATE rear skid plate, won’t hang up like the chunky skids and lasts forever
- Fioroni Dual Action Pistons + Tekno Delrin piston assortments.
- Mugen Ti Screws
- LCG lightweight motor mount
- Center/Front Aluminum Driveshaft
- Aluminum Hinge pin Braces (outboard)
- Aluminum Steering Rack
- 2.4 swaybars F&R + stock bars
- Carbon Front Shock Tower
- Delrin shock guides
- Lunsford Ti Links
- Tekno +1mm Aluminum Wheel Hex’s
- Pinion gears
- Servo horn... tried a few, this worked best but forgot who makes it
- Mugen joint pins for center driveshafts, much better than Tekno's
- Stock chassis
Any trades?
