Kyosho Truggy
Kyosho Truggy
What kind of initial upgrade do I need to make to the steering servo? What Brand or type.
Thank you, I need all the help I can get.
Great, Thank you
Now if I could get the damn thing from dying once I give it gas I will be in good shape. It was running fine at the track but at home I was running it at the park and it just took off and would NOT stop then it hit a huge water puddle and I haven't been able to get it tuned correctly since.
Servo Upgrade
I have a Kyosho Truggy and I think the best sterring servo is the HITEC 5955TG. Great Speed and awesome troque. Make the big investment and you won't buy another servo again.
i was told the new hobbico servo cs-170 is the same thing as the hitec 5995tg and it only costs about 85 $ just my two cents
The KO Propo 2386 is THE best servo for truggy steering. It will mash all those others into the dirt, and come back for seconds. It's a little more $$ initially, but very strong. Also, if you run lipo, these servos can take the voltage. They won't burn out if something happens to your regulator.
How much are we talking about for the Hi-Tech steering servo?
HITEC PRICE
The HITEC sells for about 90 online. Its Digitial has awesome power and plan and simple works without failure. Servos are almost a pay for what you get kind of thing I'm sure less troque will get it done but they will fail and if I can get 2 for 1 and just make the intially purchase seems like less of a hassle.
If you plan to race back any steering servo you own with a HS645. It will get you through in the event any servo goes bad and at 30.00 if you do burn it up atleast you can still get from Qual's into your mains.
Too much for what you get. OK about $115 to $120. But save some money for postage to send them in for repair.
I only use hitec servo's for some of my back yard bashers !!
Futaba and KO are what i use, yes you pay a bit more up front(for similar spec's to hitec) but it's well worth the extra !!
