Like Tree11Likes
Tamiya TB04 Pro
Old 08-13-2014, 11:53 AM
  #826
Wade....'s Avatar
Looking for a 64p spur that fits... what are my options? They are a special fit right?
Wade.... is offline
Old 08-13-2014, 11:59 AM
  #827
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Any standard spur fits. Use two screws and a dab of thread lock.
If you want to run 17.5 or less, buy a 72 tooth spur or smaller if you can find it.
CraigMBA is offline
Old 08-14-2014, 04:30 PM
  #828
Raman's Avatar
Trader Rating: 94 (100%+)
That's which the Exotek motor adapter right?
For pinion.. 52T?
Raman is offline
Old 08-14-2014, 04:44 PM
  #829
CraigMBA's Avatar
For pinion.. 52T?
That's one option, or you can grind the inner radius out on the stock plastic one, takes about thirty seconds with a Dremel, can't tell once installed.
CraigMBA is offline
Old 08-16-2014, 09:40 AM
  #830
Raman's Avatar
Raced the car last night in RCGT / GT10 class. Traction was pretty poor, at times it felt like a drift class. Car was great, very balanced. I played a little with rear settings, switched from D to E block, placed 1mm shim under blocks... I noticed minor changes at beginning of race, but once traction compound wore off.. Was hard to tell.
Overall very pleased with the car. Had a couple of mishaps, no broken parts!
Raman is offline
Old 08-16-2014, 03:14 PM
  #831
Default servo mounts
Does anyone know about aluminum servo mounts for a TB04 ProII? I stripped one of my plastic servo mounts and I would like to replace them with some blue ones. Thanks
Old Vetter is offline
Old 08-16-2014, 04:03 PM
  #832
Raman's Avatar
Check the TRF418 manual on TamiyaUSA for the part number. Should have it
Raman is offline
Old 08-17-2014, 07:01 PM
  #833
Does th TB04 Pro use the same suspension mount bars as TRF418? I just changed the a-arms and wondering if can I can change the aluminum suspension mounts too.
xzeratul is offline
Old 08-17-2014, 09:20 PM
  #834
Raman's Avatar
Yes.. they're are completely the same.. fully compatible
Raman is offline
Old 08-17-2014, 10:59 PM
  #835
VooDooPH's Avatar
Trader Rating: 18 (100%+)
short:
http://www.rcmart.com/tamiya-54091-t...h=595_744_1229
long:
http://www.rcmart.com/tamiya-54090-t...h=595_744_1229
VooDooPH is offline
Old 08-17-2014, 11:47 PM
  #836
I'm using the ones from RM01 when combined with direct servo horn (futaba in my case).
torg is offline
Old 08-24-2014, 01:21 AM
  #837
TB03Racer09's Avatar
I have installed and tested the dcj shafts, I am very happy with them.
im having a bit of trouble getting even steering throw. The left is 34deg and the right is 31deg. What angle do people normally use for their touring cars? Should I set steering throw both at 30 then use other tuning options to help it rotate better?
TB03Racer09 is offline
Old 08-24-2014, 06:02 PM
  #838
Wade....'s Avatar
Default worked like a charm
I have been having issues during my build regarding the transmission output shaft binding and the top cases not sitting right on my TB04pro II build. Basically the same ones already mentioned earlier in this thread by others.
It seems all of it is due to poor top case plastics not fitting right on the thinner of the two 10mm bearings on the output shafts. A touch of a grind with my dremel and everything is dare I say... 'free'. I hardly removed any material, but it made a world of difference.
Wade.... is offline
Old 09-01-2014, 09:33 AM
  #839
Raman's Avatar
Raced the Pro II again in RCGT. Traction was much improved this time around. Car felt really consistent which says a lot because I am not so consistent as a driver. It took a good wack in the second heat, popped off front right shock.. amazed I did not break anything.. the softer plastic on the arms helps a lot.
The transmission has broken itself in and is feeling pretty freed up at the moment. Still running stock kits gears (non re-enforced) No problems thus far.
Raman is offline
Old 09-01-2014, 11:20 AM
  #840
9and3's Avatar
Originally Posted by torg
I'm using the ones from RM02 when combined with direct servo horn (futaba in my case).
I'm guessing you're running without a servo-saver. With a fender'd body, I don't understand with benefits of using one, but I'm new road cars. Is skipping the servo-saver standard or recommended practice? Thanks.
9and3 is offline
