Tamiya TB04 Pro
#587
I'm speculating based on the detailed description, images plus the hop up parts list that has been released.
If in wrong, it won't be by much.
#588
TB-04 PRO II CHASSIS KIT
Item No:84382
2014年 6月28日(土)ごろ発売 31,104円(本体価格28,800円)
2014/06/28 Release in Japan / Yen : 28800
www(dot)tamiya.com/japan/products/84382/index.htm
TB EVO.6 CHASSIS KIT
Item No:84379
2014年 6月28日(土)ごろ発売 60,264円(本体価格55,800円)
2014/06/28 Release in Japan / Yen : 55800
www(dot)tamiya.com/japan/products/84379/index.htm
Item No:84382
Item No:84379
#590
HI, I had the same problem of yours. Please let me know if after you fit the DB-02 bevel gears you had any kind of issue. I am thinking of buying the same DB-02 bevel gears to put in mine. Thanks
#591
The spur gear holder shaft. You need to shim it so it's free spinning with no side to side movement. And repeat on the other areas with small gears. That will fix your gear problem
#593
Std hard case lipo batterie are fine.
#595
Thank you for the hint. I will try this. Yesterday i went to a local hobbyshop and bought a bevel gears set. Actually i am using a too powerfull motor ( yokomo 3.5t ) on 3s lipo, this is the other reason i was looking for metal gears.
#597
3.5t!!
Way too much motor on 2s let alone 3s I expect!
Be interested to hear how you go and how airborne it gets
#600
I've tested it last weekend after the adjustments, the speed is insane!!! I didn't reach the top speed, I was concerned about the narrow street, but once again the plastic bevel gears were smashed lol... by the way, the TB04 is a great car for handling. I've ordered a DB-02 aluminium bevel gears set in order to fix the problem. Later I will post a video.
