Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-05-2016, 06:05 AM
  #25396
thecman26's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Gearhead82
Do you have the name or a link for the lubricant pen you're talking about? Sounds like a good idea.
Honestly if you know a diabetic person who uses insulin.
You could just borrow a syringe, would work perfectly!
thecman26 is offline
Old 02-05-2016, 06:14 AM
  #25397
Mason's Avatar
I'm not sure "borrow" is the proper term here. I have a feeling no diabetic really wants it back after you have used it.
Mason is offline
Old 02-05-2016, 06:26 AM
  #25398
Lol...
youngrigo is offline
Old 02-05-2016, 06:53 AM
  #25399
thecman26's Avatar
Bunch of smart A's in here isn't there?
Old 02-05-2016, 07:08 AM
  #25400
Darkstarr's Avatar
Default Need a Bit of Info
Hello fellas , I'm doing the Championship Edition upgrade on my . 5M ! My question is ? Do I need to get a different Top Shaft ? Because the one out of the 4 gear trans won't fit , the Bearing. Any help would sure be Appreciated ! Thank You Lorne M Slan
Darkstarr is offline
Old 02-05-2016, 07:43 AM
  #25401
it would appear that the proper bearings are included in the CE kit.
bshack is offline
Old 02-05-2016, 08:05 AM
  #25402
CCristo's Avatar
Trader Rating: 56 (100%+)
Search eBay for pen oiler. There are several variations.
CCristo is offline
Old 02-05-2016, 08:12 AM
  #25403
MiCk B's Avatar
Hi,
Avid to empty pen oilers:
http://www.avidrc.com/product/5/acce...cessories.html
MiCk B. :-)
MiCk B is offline
Old 02-05-2016, 08:36 AM
  #25404
https://www.amazon.com/dp/B000KKHNU0..._V5mTwb7KHNEKE
This is the one I used. Won't get banged up and crack in your tool box and it is refillable. The others would work well if you are just keeping it home or in a safer place.
As for a syringe, if you are not used to working with them then stay away from them.
No need to go crazy with the oil though, just enough in there to coat everything.
Just2much19 is offline
Old 02-05-2016, 11:46 AM
  #25405
You need the new top shaft part # 91606. It uses the same bearings as the idler gear shaft.
islandscott is offline
Old 02-05-2016, 11:54 AM
  #25406
Just received my SMC 4400mah packs and I have to say I'm digging the shorty packs..lol
I guess it just didn't sink in how much smaller they are till I got one in my hand next to a 5000 standard..
Tires and wheels should be here tomorrow and then I just need to settle on what electronics I want to order. Then the rewiring..
RcJunky76 is offline
Old 02-05-2016, 01:06 PM
  #25407
I just ordered two of the same packs, can't wait to get them. I have to do a re-wire too, I'll save that for last.
Old 02-05-2016, 01:28 PM
  #25408
There nice packs and only took 3 days to get to me so am very happy.
I'm waiting to get everything together before I even attempt at wiring. Being my first buggy this is very tight and I want everything figured and in place before I tackle what at this point is looking like a cluster..lol
Oh and if you have the side foam in battery tray you will need to remove. The packs are tight side to side..
Old 02-05-2016, 01:44 PM
  #25409
Volition's Avatar
With the wing shim, there's a boss for a screw across from the usual mounting points.
I assume they are for extra bracing. Does anyone use it? What's people opinions on using the extra screw boss? Would the screw need a washer too.
Volition is offline
Old 02-05-2016, 03:30 PM
  #25410
TC5Driven's Avatar
Trader Rating: 13 (100%+)
If your talking about the wing angle piece on the wing mount, yes I use that screw to tighten up the wing against the body clips that hold the wing onto the mount. It does give it a slight angle though.
TC5Driven is offline
