Freakin hot GTB , help please.
Hi guys, i went to run my normal GTB in my car (not the 4 cell one ), but i ran 4 cell and my gearing was 17 tooth pinion and 55 spur and my motor wasnt that hot but my GTB it was freakin hot , it was so hot that even my chassis underneath was very hot .
Is it because my gearing was too low or is it something else. i wasnt using it in my car but in my buggie and 55/17=3.2 and when i run it in my HB cyclone , 32/108 =3.3 .
I was running it in my 2wd buggi and it was a 3.5BL motor with 4cell with a fan on the GTB.
Whats wrong ?
Thanks , any help will be much apreciated .
Whats wrong ?
Whats wrong ?
Whats wrong ?
Its just that my GTB was hot,
Yes , its a tamiya DT-02 sand viper , this one
http://www.fusionhobbies.com/Product...A58374&click=2
also i dont know wich pitch is has , its not 48 neither 64 ??
Well the FDR on your Cyclone is 7.128 (3.3 gear ratio * 2.16 internal ratio).
The FDR on your Tamiya buggy is 9.28 (I believe) which would mean (3.2 gear ratio * 2.9 internal ratio).
I got the 9.28 for the buggy off the Tamiya webiste.
Buggy linky
It says gear ratio so I could be wrong. I don't know if a higher or lower FDR makes the ESC work harder but that could be your problem. What motor and batteries are you using with the buggy? What types of connectors also?
Buggy linky
Buggy linky
Buggy linky
Thats very very usefull , because the the motor should be geared at 8.2-8.7
So i think it explains alot but what i dont get is the pitch for this buggy , its not 48 neither 64
Thanks for helping me out with the ratio.
Thanks again
32 pitch I believe
13T pinion
18T pinion
The part number for the 17T pinion that you have on now is 3515005. A 19T is an optional part and the only other one that will fit without modifications.
Here is a thread that you could look-over for some ideas too:
Tamiya DT-02 Thread
13T pinion
18T pinion
Tamiya DT-02 Thread
