Did I forget anything?
#19
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Battery for the starter box, 2nd servo (get both the same) paint for the body, fuel (get a good brand... I run O'Donnel, but I also like Nitro Juice and Byrons Gen 2.)
A few spare parts would be in order if your local shop doesn't carry them. At the very lease a set of front arms. A charger for the batteries if you don't have one.
Nitro vehicles require a LOT of wrenching. I suggest that you consider getting a little battery powered screwdriver, and order a set of tips for it.
A flywheel puller for the engine would be nice. A 10mm deep-well socket to tighten the flywheel nut... that is a MUST HAVE as well as a set of vice grips or other method to hold the flywheel while tightening it... don't worry about scarring up the flywheel, it doesn't matter performance wise. A clutch tool to remove/install shoes is nice but not mandatory.
And rest assured, you bought one of the best setups money can buy... truggy, engine, servos, and radio are all top-notch equipment!
#20
I cant belive i went this long with out buying a power screwdriver, now that i got one it has cut my diff oil changes time in half. Its not a msut ahve but sure is nice !
#22
Same one I use... it is not variable speed, but it does have a "clutch" to keep from stripping things out. Best $29 I've spent in this hobby... you can get them at your local "Home Depot Racing" store.
