Xray T2'007
#2597
As rmargiotta says... I also use bearing lube on my axles joints as well.
#2598
I'll clean them out real good tonight and lube them and see what happens. I have a few "gurus" in the area and a team driver at my local track...but he's new to the team
Spence- I don't think I'll be able to make it to the FT race because of prior commitments, but I'll be at the eXpress race. Hopefully I'll have it figured out by then, but if not I'll be hunting you down!
Thanks to all for the help.
#2599
Hopefully I'll be making the Express race too. Maybe... If so, catch yall there...
#2600
killing, one thing I do to make sure my CVDs are built decently is a hand swing test. I grab the axle with my fingers, and let it all hang down. Then I swing the axle in circles (wrist action, like stirring a cup of coffee). The dogbone should swing in circles, too. If it just swings back and forth, it tells me it needs lube, cleaning, or loosening.
#2601
Originally Posted by t4m1y4niac
how is the dry lube works???
it goes on wet like any lube, but they drys and leaves a lubricating film that doesnt attract dirt.
#2603
Originally Posted by havy
No prob, the Maxamps fits w/ room to spare, and inside the standard 6 cell designated area.
i have a question about the chassis. I have the Us carpet version but also go the thinner chassis w/ the upper deck EU version(?). Here where I live its strickly outdoor asfalt tracks, should I use the EU version chassis to run the car? I was thinking of using the EU version while here for practice (we don't race electric anymore) but I want to keep the US version to race in a big carpet race sometime next year after they legalize lipo and sensorless motors...( hopefully by next year). Until then I will travel to run my RRR only, but really want to get to go to a big electric race, maybe Las Vegas or something in the future.
SO for asfalt, is the EU version chassis really better?
Havy
Havy
The US chassis is designed for FOAM TIRE
In other words;
The EU chassis should be run on Asphalt AND Carpet when using RUBBER tire.
The US chassis should be run on Carpet when using FOAM tire (probably the best choice for FOAM an asphalt as well however it is not COMMON to run foam on asphalt so I assume Xray did not take this combination in account when desining the car).
Is there a combination I'm missing
#2604
T2R?
Why won't Xray make them for the masses? My local hobby store says they won't get any until Aug. What ups with that Xray?
#2606
#2607
Originally Posted by bigb11
its the same thing here. my lhs says he can't get parts from xray. i wont use my xray because i can't get parts.
If you have any issue in getting spares please contact Xray directly on their forum of by email: [email protected] or contact xray USA by email: [email protected]
Good luck, and start using your xray again
#2608
#2609
hey i have a little handling issue and was wondering if you could help. Im running a t2 07 in 19t and i find that the rear of my car although it grips really well sometimes it can break loose if i am to eager to turn into a corner and i was just wondering if anybody had any setup tips to maybe get a little more rear end rotation instead of the 'snap' that i get at the moment. I am running kit setup but with a diff up front on a large outdoor asphalt track
