Schumacher Corner
Best method (IMHO) for drilling the 3rd hole is to fill the std 2 up first. In the US we have an epoxy called Araldite - ideal for the job!!
ok set up is as follows:
front
40wt oil
hole 3 on tower
1.5mm vert shim
3mm horizontal shim
1mm width shim
1.5mm roll center shims
3mm behind wishbone for wheelbase
short lenght mid width ackerman 1 hole forward
spool
rear
35wt oil
2mm vert shim
2,5mm horizontal shim
2mm roll center shims
mid wheelbase
3 deg toe in
this set up was on med traction carpet on muchmore 32 tyres
hope this helps
front
40wt oil
hole 3 on tower
1.5mm vert shim
3mm horizontal shim
1mm width shim
spool
rear
35wt oil
2mm vert shim
mid wheelbase
3 deg toe in
hope this helps
Cheers, what width/toe-in shims did you use at the rear?
And were you using Sch white springs?
Is the kit toe-in (2mm front, 0.5mm Rear) 2.4 deg?
Skiddins
Now if we could only get Schumacher to make it right, but I've been asking for years
Is that Wright???
width shim=Screw Block Spacers
vertical shim & horizontal shim=Link Washer (horizontal&ver.)
roll center shims=Pivot Block spacers
Cheers
Cheers
Got it. I just got 10 mm from you saying you took 4 mm off from the shorter ball cups which measured about 14 mm on my car. In the end all that matters is that you have a cup thats roughly 11-12-13 mm. I am a bit bewildred as to how you got your shock length down to 59.5 mm though. I couldn't get past 60.5 with the cup threaded as far in as I coud get it. Weird . . .
"berry berry sneaky"
Like Randy said, I used an under sized bit. Reamed the hole slightly with my reamer and then threaded the ball-stud into the new hole. Filling the std holes with 5min plastic epoxy would obviously be the best thing to do.
hi guys! what spring rate are the springs that come in the box with the kit?
14 lbs. They're actually a little stiffer but that's what they're rated at.
I definately felt the difference in my car at the ROAR nats between mod and 19t. I was using the stock 6 cell chassis, front 5 cells for mod, 6 cells for stock. The mod car was definately more responsive, the 6 cell car was a bit more sluggish in the corners. I never really worried much about the weight of the car before that race, but after feeling the difference firsthand I try to get the weight down now.
On my cyclone i just put them on the end of the cell per normal, but in the MI3 the belt runs too close.
Most people run a battery bar up from the end cell and bent at a right angle so the tube can be mounted 'on top' of the pack.
Hope this helps, sorry for the poor image quality.
My corally connecter clears the belt quite confortably
