Tamiya TRF416 / TRF416WE / TRF416X
#8522
I use 2 pieces of K&S aluminum square tubing that you can buy at most hobby shops, the tube is about 2.5mm thick and I have it run the length of the chassiss from the motor mount to the servo mount. Its just shoe gooed in and when you use 2 of them side by side it will move your Lipo battery out to the edge of the chassiss, almost perfect, for weight balance. It makes it really easy to tape your batteries in and there is no chance of them moving into your belts.
#8523
I just like the clean, near factory appearance of the carbon fiber.
#8524
Nice thing about my method is you'll never knock a weight off from a side hit. Some guys that do this paint the tubing black to blend in with the chassiss, it also gives proper belt clearance if you do the belt flip mod on your car. Of course the CF is a nice piece too.
#8525
#8527
Not a problem for me either, but I have one Lipo pack that has a dent in it from being t-boned, and it was a hard enough hit that it bent the aluminum bars I mentioned above. It probably depends on how your mounting your stuff as well, if your using a lipo plate and double side tape or if your packs have the locator bumps, and of course how far out your trying to move the lipo for balance.
#8528
Locator bumps seem to be a bit out of favour with the manufacturers at the moment, but I never had a problem running my old 28C SMCs without them. Just make sure you file the tape slots real good and you wont have a problem
I just picked up my smokem chassis today. It feels slightly thicker than the stock chassis and it has less cutouts so I'm expecting it to be a bit stiffer out on the track, it looks the business though and I love how narrow all these lipo decks are
#8529
steven
#8530
I too received my smokem chassis today , can't wait to test it tomorrow. Got the steering brace too. Please advise if you encounter any adjustments or setup changes.
#8531
#8535
Thanks malkiy.. does it fit nicely into 416we? or do i need any modification on the bearing housing or bulkhead?
i heard that the front one way set for DB01 can also fit into 416we. does anyone can confirm on this?
http://www.tamiyausa.com/product/ite...oduct-id=54017
macam mana?? dah test ke oneway diff tu??
ok ke?? brape kalau nak beli??
ko dari mana?? kalau free pm laa aku!!
