BMI 1/12 conversion/car
#1321
Originally Posted by TimXLB
Merciless/Tim:
Hi,
I will bring this up to Jason tomorrow when I talk with him. seems there more than a few who seem to want this option. I will ask him about doing it the way we talked about Sunday night.
earlier in this thread this was discussed in length.....somewhat. Wayne (sg1) should be the one to give the answers as it is his design. hopfully he will be on a little later tonight.
Hi,
Thanks!
#1322
SG1,
You gotz'a PM. Sorry for the delay. Worked 27 hours in the past 2 days with muscle and nerve damage in my right arm from electrocution. Fun stuff. If people at work don't stop calling me sparky, i'm gonna snap.
I didn't want to look at a computer much less use one.
Tim
Tim
#1323
OK -- quick question.... I am running on a carpet track with Pink rear and Purple fronts.....as I let off the gass in a corrner the rear end snaps around. I have tried less D/R in the radio, less to no tire compound with the same results....any thoughts?
#1324
post your setup.
most of the time you get that to happen when the front end has too much tracktion. it could be that the front is digging when you let off.
#1325
Tim,
Back at ya!!
Micro Racer,
Theisgroup is right, make sure the front end has atleast .020 or .022 springs and that they are the same length and don'r "sag" when the car sits. Depending on what manufacture's tires you run, the offset may be different for the rears and the width of the fronts vary. Make sure your rear track is wide as possible and you can super glue the edge of the fronts to prevent some tire "roll". I even go as far as narrowing the front tire .06" to make it smoother threw the turns. The center shock and t-bar might need to be looked at. Make sure the center shock can travel in both directions, so the piston doesn't bottom out when you pull back on the rear pod. A .072" to .075" t-bar would be a good starting point too. I never run the pink rears in stock, maybe try CRC magenta. Just a few things to look at...
Wayne
Back at ya!!
Micro Racer,
Wayne
#1326
Thanks Wayne......will look at the above!
#1327
Micro_Racer - Make sure your rear tires are exactly the same size.
#1329
Yep I'm still running 12th scale. My setup has changed slightly, now 40wt in the shock and red-stuff on the plates. The car is still easy to drive and smooth. I've got some tires coming in monday; purple/magenta, purple/gray and magenta/pink. The purple/granite combo that I was using worked well, but I'm sure the car can go faster with different tires. After a few months of practice the car is getting better and better. My packs are still working great and now dump like crazy, no more lap after lap slowing to a crawl. Still 4 ounces under weight, steel screws on the base of the chassis would fix that. Q? How should I adjust rear droop to gain some on-power steering?
Thanks,
Matthew
Thanks,
Matthew
#1330
Originally Posted by sg1
Anyone running 1/12 still??
#1331
#1333
fatdoggy...
Set the length of the shock approx. 3/32" longer then what is needed. I usually set the car on the table with no front tires on and take the diff. out, so the chassis is flat on the table. Then adj. the ball cup ends so when the front cup is snapped on the rear cup is approx. 3/4 of a cup too far. Snap it on then and adj. the collar so it just touches the spring. Adjust tire diameter and ride hight adj. so you get your proper ride height and chassis rake. You don't want to add preload to the shock spring to get your ride height, your droop will be changed.
Rick,
With the side shocks, you may want to try more dampening. What oil did you try? On carpet I was at 50, I know Jason ran very heavy dampening in the washers when he ran them. You may want to try 80 or so and a heavier spring. Wolf makes a black spring that works well. I have some if you can't find them.
Wayne
Rick,
Wayne
#1334
Rick,
Wayne
Wayne
Rick
#1335
LOWERED POD PLATES
Can i assume the only work thats been going on towards making these a reality is in my head ???
There seems to be a fair amount of interest in these , I was assured they'd be made, in what seems months later we still have no word on when you might get around to helping us guys out with some ?!?!?!
COME ON PLEASE SUPPORT YOUR CUSTOMERS WHILE WERE STILL OF A MIND TO SUPPORT YOU
