"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
#811
jonest,
Great to hear that as the latest design remain backwards compatibility with the former models.
dodo,
Thanks for the feedback, at least for sure the screw orientations are different.
Contrary to that Jills did mentioned "To upgrade your "old" 416 to the X you need the rear bulkhead, rear belt and topdeck. You can't use the new front bulkhead on the old chassis."
Anyone can assist to provide the Tamiya P/N all neccessary parts to make the conversion possible. This will eventually reduce the same question from others. With the p/n ppl can look up themselves... Thx in adv.
dodo,
#813
Just try diff setup for my end.. To others their requirements are different.
#814
Hello JGH,
Just a question regarding your tight ball diff in your MO5M. Which ball diff did you use? The new MO5 ball diff or the old TAO3 ball diff?
Sounds like the new Ride mini tyres might be pretty good. Are they as hard wearing as the Ride 3035's?
Enjoy Singapore.
Thank you.
Regards,
Calvin.
Enjoy Singapore.
Thank you.
Regards,
Calvin.
#815
Hi, Jilles
Would you please share the setting of Ride tyre in RCA? Thank you in advance.
#816
Hello Jilles
I'm building my 416X now, the car went together very well.
2 questions:
- Are you using the original diff screw or something else?
I found the screw a bit short, high risk of stripping.
- More important for me:
I have issues with my Lipos (LRP 5300 and Boomerang, EP 5200)
The (- Minus) socket is exactly below the topdeck. I don't want to Dremel, it would weaken the top deck too much. I'm also scared about dremeling the Lipo-Pack. I'm sure you have tested with Lipo's, any ideas?
Thanks in advance!
2 questions:
Thanks in advance!
#817
Hello Jilles
2 questions:
Thanks in advance!
2 questions:
Thanks in advance!
http://ets.redrc.net/gallery/
#818
Hi jilles
I have been using my 416we with your euro setup and adjusting
droop to suit different track and it has been quick
how will my new 416x differ or should I build it the same way
Have you got any setup tips for it with the chassis
Thanks in advance
Wayne
Thanks in advance
Wayne
#819
Orzal24,
The differents in Stock and Modified is not much, the cornerspeed is about the same. In mod you have little more torque so normally little more toe-in is required.
Calvin,
The last race I tried cleaning cum( this what you use to clean gascar ) in my geardiff. You actually make almost a spool as the diff doesn't work anymore.
This gives really good on power response(no diff slip anymore) but little lack steering out of corner. Before I use old M03 balldiff. Will try M05 balldiff later as soon as I get one. The Ride tyres for the TITC are very low wearing and good traction, not as good as Sweep tyres but for all drivers same. The TITC controlled tyre is also bigger then the previous Ride tyre (3035)
srw_g,
Setting for Ride Tyre is not much different as with other tyres at RCA.
One thing I noticed at the Futaba Cup was that old tyres worked better then new tyres. Beginning of Februari is a TITC warm-up race(Ride Cup) so good time to prepare.
Nutsisneat,
I'm sure that the diff is the same as the previous models so no changes there. I quess you need to tight the diff little more then.
I use Orion Lipo's with the wire/plug coming out of the side, so no problems with plugs. Maybe check some pics from Marc/Viktor's car at recent races as they use SMC packs with plugs.
Wayne,
No need to change setting for your new ride. You might need to play little with your balance weight if more weight is reguired.
All Happy New Year!!
Jilles
Calvin,
srw_g,
Nutsisneat,
Wayne,
Jilles
#820
Thanks JGH,
I don't think I have ever heard of cleaning Gum (cum ), however I will stick to the anti-wear grease. Thank you for your information regarding the tightness of the ball diff and the ride tyre. Does the tyre have a round or square edge.
Do you know what type of insert they will be using in the handout tyre for mini?
Thanks again and have an awesome New Year.
Regards,
Calvin.
Regards,
Calvin.
#821
Hi Jilles,
In some races, organiser implement that max heigh of the rear wing not more than 115mm (which is the min height of the car roof) instead of IFMAR's not exceeding the height of the car roof (115mm - 175mm).
I just wonder how they measure it in Thailand / TITC?
#822
Hi Jilles,
#824
Hi, Jilles.
Happy new year to you and everybody.
Question, you run a rc motorbike at heemstede, wich one?
Best regards
Ed IJzerman
Best regards
Ed IJzerman
#825
Hello Jilles
If running on asphalt and traction is low, should I lay down or stand up the shocks more? What other setup can help?
Thanks.
Thanks.
