Yea i don't blame you don't exactly care for them ethier prefer gear diffs but if you break them in good, and keep it from barking they actually last long and smooth . No need for the carbibe balls the MIP rebuild kit is cheap and good .
But 3k or 2k should work on loose dirt i think .
Ball diffs are the easiest to build and if properly built and broken-in, will last a long time and give much better results than a gear diff.
Ball-diff: low to high traction
Gear diff: uber high traction
Is there a part number that can be ordered to use to mount the wing on the JC wing mount? Apparently you have to provide your own hardware?
Please help. I'm considering buying a B5M. my last buggy was a b4.2 and loved it, but been out of the hobby for a little while.
I'm thinking either the lite, or the Cham. edition.
I will be racing on turf. (Stock)
Also considering waiting until the laydown tranny comes out.
Any advise or suggestions would be great.
OK I might be wrong but here is my thought. I tried something at my local track. It was a new layout and buggy was just a little rear end happy in the corners. Now I know many will say, " track hasn't come in yet". But I know other cars were not doing the same as mine so tried a change. Instead of running my camber links on the rear ( in on rear tower and middle on hub) I went to (in on rear tower and in on rear hubs. I was hoping for a little more camber gain in the corners.
Anyone have a FL they want to sell?
If you are on a high bite track lengthen them it will make the car less twichey. On a loose track shorten them you will get more camber gain. On a high bite track you don't need as much camber gain.
Yeah I have too. Seems like I always miss Them.. And sucks even more since I lost the PW to my old user name it wont let me post the stuff I'm trying to sell.
Oh and was going to ask. Since I'm pretty sure I'm going to get a FL. Are there any recommendations or "Must Haves"?
There might be some nice things to have but nothing necessary. Like ceramic bearings, cut gears, etc...
