The Speed Passion Thread >
Like Tree57Likes
Old 02-21-2011, 03:36 PM
  #6601
mr crum's Avatar
Originally Posted by ChefDementia
Tried a new sensor wire this weekend and the problem is still there.
then it has to be software issue does anybody local to u with the program lcd box
mr crum is offline
Old 02-21-2011, 03:56 PM
  #6602
ChefDementia's Avatar
Trader Rating: 19 (100%+)
Got a hold of one today, what software should I put on the esc?
ChefDementia is offline
Old 02-21-2011, 06:52 PM
  #6603
mr crum's Avatar
what are you running car, motor, class ect.
mr crum is offline
Old 02-22-2011, 05:06 AM
  #6604
ATM i have it in a blitz with a 10.5 but run a 13.5 some nights too.
Old 02-22-2011, 12:13 PM
  #6605
Hey guys
I have decided to jump ship from stock to modified this year and have bought a GT2.0 speedo and Speed Passion 6.5v3 motor ,
now as i am a complete beginner at mod class i want a nice friendly set up for my T3 so that i can learn how to handle the power .
I have been racing stock with a Tekin RS and 13.5 speed passion motors for about 2 years so the speed differance shouldnt be too much but any help is greatly appreciated
Thanks Phil
sidecarphil1 is offline
Old 02-22-2011, 04:55 PM
  #6606
mr crum's Avatar
if you are running spec you should use 508 no timing but if you can run open speedo the i suggest you run 110212 it has boost i would go with default settings at first and drop 4 teeth on the pinion and remember flash the software on esc twice
mr crum is offline
Old 02-22-2011, 06:21 PM
  #6607
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Did anyone else have a little trouble soldering wires to the 2.1 ProStock ESC for the first time?
I was easily able to tin the tabs, but as soon as I tried to solder wire to them, the alloy heatsink/case sucked the heat right back out
I changed to a larger iron tip, and turned the temp up to max (450*C) - Still had a little trouble, but got them on there .
[[john]] is offline
Old 02-24-2011, 04:33 AM
  #6608
SCTom's Avatar
This thread has been alittle quiet the past few days, so I just wanted too share my thoughts about new software. I loaded 101212 stock on my GT pro stock v2.1 esc. Everything works well, almost too much power for 2wd short course on medium traction track. Running 17.5 DOU 3.
SCTom is offline
Old 02-24-2011, 04:36 AM
  #6609
Trader Rating: 125 (100%+)
What are you geared at? Settings?
kwiksi is offline
Old 02-24-2011, 04:50 AM
  #6610
Trader Rating: 12 (100%+)
I just purchased a gt2.1 pro stock to use with an epic d3 21.5. Is the newest software (101212) best to use? Or should I just use whatever it has on there already. I'm completely new to lipo/brushless (Haven't raced in 4 years) so not really sure what I am doing.
J-PaP is offline
Old 02-24-2011, 06:01 AM
  #6611
Craig W's Avatar
Hi was going to replace the rotor in my 13.5t v3 and I was wondering if the change it to the super 7 rotor or stay with the original 1
Craig W is offline
Old 02-24-2011, 06:47 AM
  #6612
irgo's Avatar
it seem that Speed Passion not releasing the 3rd generation Firmware yet,
irgo is offline
Old 02-24-2011, 09:52 AM
  #6613
SCTom's Avatar
SC10 geared at 26 pin. and 75 spur.
17.5 DOU 3 Venom 5000 40C.
esc settings 101212 software.
4=6
9=8
12=6
13=2
14=1
15=4
temps. in the 150s after 5 mins.
SCTom is offline
Old 02-24-2011, 02:45 PM
  #6614
Trader Rating: 17 (100%+)
Originally Posted by sidecarphil1
Hey guys
Thanks Phil
check out these setup....since you are running a 6.5 you have to gear up a little. I have a setup with MOD motor and boost, you can adjust your setting to more aggressive them mine (I was running 4.0)...
Or the good old 205MOD software are always a winner...good luck.
Solara is offline
Old 02-24-2011, 06:12 PM
  #6615
defcone's Avatar
Trader Rating: 15 (100%+)
What I did was tin both the wires and the tabs a little bit, then put the remaining required amount of solder on the tip. Then hold the wire against the tab and let the solder on your tip touch the wire and should flow onto the tab.
defcone is offline
