1/10 R/C F1's...Pics, Discussions, Whatever...
#5941
F104pro here, carpet racing, stock foam
Tires. 17.5, 2s, etc. car just flips suuuuper easy. Do you guys cut down the foam tires like 1/12th scale? Or round the corners? I'm trying to make it drivable as of right now, and hopefully generate interest to run them around here as ZERO run f1.
#5942
What is the difference between these tires??
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
Which do you think would be better for indoor carpet oval with a 2S LiPo & silver can motor?? I need the f103 tires for my f109.
#5945
What brand of 21.5 do you guys recommend? Build my new F104 v2 this week, just need a motor. Thanks!!
#5946
#5947
They are more or less the same, the main difference is the design of the T-piece and lower pod plate. I would first find whether you can run wide cars or not. If you can run wide cars then go for the WGP.
#5950
1) Front uprights on my 104WGP came with the adjustable metal units anodized in black. My 104X1 came with carbon re-enforced parts.
2)X1 comes with a rear shaft counterweight, 104WGP comes with a clamp type rear hub along with aluminum gear case (all anodized in black).
3)The 104WGP takes F103 wheels/tires and comes with a carbon fiber lower deck.
hope this helps.
#5953
Out of curiosity, why the thunder power motor over a trinity or reedy?
#5954
Honestly because that is what I have. But, Ive been running mine since March, as have a couple of guys I race with, and its fast out of the box, we havent messed with timing or anything. Just simple. plug and play. MKennedy can tell you more, all I can tell you is it is a stout motor.
#5955
