Blow Out Sale.......
Factory TeamNTC3..........9550's.TZ12 3port 1 1/2 gallons Lotta Pinch Orion 1600 rec pk....
New Parts....not on ,come with..........Carriers,Arms,Diff Cases,2 Blue Alum,Towers,pivot balls,hindge pins,clutch shoes,swing rack,shock rebuilds,1 set of outdrives,clutch bearings,brake pads,blue bones,wheel bearings,pinnion gears,diff bearings,3 diff rebuilds,1 set outdrives,2 glow plugs,has version 2 shock upgrade and rebuild parts,comes wih a extra FT pipe and an RD pipe,Has a Spool up front comes with a oneway.....
While removing the radio gear i noticed the front end has a Problem with the rack,New one in the box....not the servo i checked it!.......
Also included Assoc. Starter box, Glow Ign,Shock oils,40-60.....
2 body's (Been Raced)...........
600.00 Firm SOLD
LST2 Bought it for the Wife at X-Mas.......5 tanks on the street plus LST parts truck.....This 1 is RTR....
500.00 NOW.......400.00
LaserZX5.......9550,Quantum2 speedo,
Part's in Pkg......Diff bevei set,carbon rear hubs 2 sets,susp bushing's,drive joint set,servo saver set,carbon shock tower ft and rear,2 ea oneway bearings,2ea spur gears,center shaft,shim set,f&r arm set,whell shaft set,bulk head set,oneway shaft,2ea diff screw set,2ea 5/64 thrust balls,
Tires on car 3 run ifmar studs.....also new tires included,Mounted and glued,Rears.....switch hard,switch w/2stage foam,ifmar pins,holeshots w/2 stage foam.......
Fronts.....ifmar pins,switch soft foam,switch 2stage foam,switch med foam,
3 sets new front wheels 1 set of rears.....2 bodys,3 wings
400.00 NOW.......300.00
MF2 truck....fresh build........9550 servo,GTX speedo,13turn motor,
Part's in pkg.......ft&r arms,78 86 spur,new tires mounted on white wheels......FT,crime fighters,step pins,ifmar pins w/s foam,switches w/m foam,usd rib on yel wheel......
Rear,ifmar pins,crime fighters h foam,step pins h foam,switches m foam,also have 1 set front and rear wheels new wht........1 used body 1 new already painted.........
350.00 NOW.....250.00
ASSOC B4......1 race still dirty broken front arm........
New parts inc........springs ,shock rebuilds,lt wt outdrives,cvd set,81 spur,thrust balls,2 sets rear yellow wheels 1 set of fronts,step pins on car,1 set rear ifmar pins mounted on wt wheel......
200.00 SOLD!
T1FK05
too many NEW part too list,2 boxes
200.00 NOW...150.00
TC4 RTR will throw in some batts......few parts also
150.00 NOW...100.00
Hot Bodys Pro Truggy
Little dirt on it.....It has the Carbon Radio stiffner and chasis brace,also has Losi bone conv........
Parts still in Pkg included......brake pads,diff pads,steering holder,diff housings,axle shaft,front hubs,wheel pins,body mounts,diff cases,ft hub carriers,diff gear set,ft &r hindge pins,2 sets diff shafts,2 sets shock rebuilds,w/ shafts,hub pins hex adaptors,brake plates,clutch bearings,carbon & alluminum Shoes,14t & 13t Bells,1 painted body one new in pkg..........
If you want too get too racingh cheap this is it!
250.00 NOW...175.00
LOSI 8-T.........
DS8711 steering 140.00,9000t T&B,Ninja 21(1 gal)JP3on now comes w/JP2,King's Head motor mounts and Radio tray Stiffner also Losi All.Chasis braces,3 air filters w/skins,Crime fighters on it.......
New parts in pkg..........
5 mm rod ends,2ea shock boot sets,Gas Tank,15mm shock ends,& bushings,clutch bearings,ft & Rear arms,radio tray,Kings head clutch springs,alum servo arm,lundsford ti hinge pins (inner),Allum rear gear box inserts,1 box 5 count Ninja glowplugs,Starter box and ign,5,7,10,000wt diff oils,1 painted body 1 J concepts in pkg.......
800.00 NOW........700.00
Tamiya M03-M
oil shocks,short springs,Allum front end,Frt Diff,LRP Mini speedo,60D slicks on car,Also NEW in Box 60D's with Chrome wheels.......2 3800 pks....1 freshly painted body........
175.00 NOW.......100.00
Mini T-Pro..Race dirty.........Hitec hs-55 feather lite servo,Novak Spy speedo,Banzi motor......
blue heat sink motor plate,Intigy alum shocks
Parts included.....stock shocks,2 diff rebuilds, arm sets,ft bulk head kit,Brace set,ft bumper,body mount kit,tires on truck are step pinsalso full set of Bowties never Ran,and rear crime fighter on yellow....2 bodys......3 batts....
200.00..........Now......125.00
All items are PLUS SHIPPING..................
MISC GOODIES........
Novak SE smart tray........35.00 now.....25.
blk dynamite lcd charger...25.00 """"".....15.
red ' '' ''' '''''' ''''' 20.00 ''''''''''.....10.
Orion Adv. charger............60.00 ''''''50.00
" " " Carbon Lipo..75.00 ............""""""65.00
Indi 0-30............................20.00"""""15.00
""""""""""" lost wires.............15.00 """""""10.00
Comp Ele...23amp power supply(very small in size)..80.00 Now......60.00
INT. 12v 6 chanel power strip..15.00 now...10.00
3600 matched pks......4.......15.00ea.... 10.00ec
3800 " " " ".....6.........20.00ea ..........15.00ea
Trinity batt box..holds 8......25.00 ........15.00
gm racing batt box.............15.00 .....10.00
Motors.....
EA stock............10.00 .....5.00
EA 19t (2)..........15.00ea.....10.00
Komodo dragon 19t (3).......20.00ea ...10.00ea
Race prep heart attack.....20.00 ....10.00
Check point 19t........20.00....10.00
""""""""""""""13x2......30.00 ....20.00
""""""""""""""7x1.........30.00....20.00
DC Motorsports...12x2,,,W/2 New arms.......40.00...25.00
REEDY Neo 1 Brushless.....40.00////25.00
GM Moitor box..............20.00...10.00
REC Pks........
1200...................20.00....10.00
Orion 1400........25.00...15.00
OFNA 1600.........25.00....15.00
""""""""""""needs new end put on.....20.00...10.00
OFNA allum car stand ...20.00 ...10.00
Racers Edge stand(Plastic).......10.00....5.00
Foam Cool Down stand w/Fan........20.00 ....10.00
Mugen Diff oils,1,2,3,7,10,000.......10.00 SOLD
Assoc&Trinity shock oils,40,45,50,55,70,80......15.00...10.00
LOSI shock oil's12 bottels,20-100...Mixture,90% are new.......25.00...15.00
RECEIVERS
Spectrum SR3000(2).....30.00 ea...... SOLD
"""""""""""Mini Pro's(3)......50.00ea... Sold
AMB Transponders......2 @ 50.00ea.........1 @45.00 needs new plug put on...... SOLD
KO Transponders.....3 @ 10.00ea.......For Squeaky'sRC......
TM Glow Ign and charger......15.00
RPM 1/8th scale camber gauge......5.00
Panther 1/8th mounting bands...5.00
Panther hobby scissors in pk....5.00
OFNA flywheel wrench 3.00
RADIO'S.....
JRXS3.....W/1RS300 and 1 rs310............50.00 SOLD!
Futaba 3PKW/Spectrum.....1 RS3000.....has the upgrade rc Carbon kit on it..Trinity Bag...200.00
Cobra com Lathe.......diamond bit....Cooling stand W/Fan.....60.00....40.00
64pitch gears.......up too 45 13 total.....40.00....25.00
48 pitch gears 13 total.....40.00....25.00
Raytech temp gun......20.00 Sold
TIRES New In Pkg..........
1/1oth offroad......Buggy 2.2
Proline rear...Slash....6.00
"""""""""""""''''Evil Twin.6.00
""""""""""""""Hole shot...6.00
""""""""Front....4 rib LP M3....6.00
LOSI REAR....X2000....6.00
"""""""""""""ifmar pin no foam....5.00
""""""""""""ifmar studs silver....6.00
Losi fronts....4wd block heads....6.00
""""""""""""""""""""Taper pins pink...6.00
""""""""""""""""""""ifmar studs no foam...5.00
Panther rear Switch 2.0 soft.....9.00
Losi 1/10th truck rears Ifmar pins red...10.00
ONROAD FOAMS....
Twister zero offsets...
FRONT.......37sch (1)box
40sch (4) Boxes of 2 are 7.00ea......
REAR.........40sch (5)
42sch (2)
Last butt not least.........
Hudy Pro all in one setup station.....1/10th.....got this last X-Mas.......250.00 SOLD
Unless you are local all items are PLUS SHIPPING!
Thank's.......
_________________
I also have 3 custom painted body's..........
1st one is cutt and punched for NTC3.......
35.00 dol's plus shipping.....
2nd is 200mm uncutt......
the tail lights havent been painted yet???
dont know what happend there!
50.00 plus ship....
3rd is 180mm......
IMG]http://i263.photobucket.com/albums/ii132/FactorySeal/nitro008.jpg[/IMG]
uncutt ready for YOUR RIDE........
65.00....plus ship....
600.00 Firm SOLD
200.00 SOLD!
T1FK05
200.00 NOW...150.00
150.00 NOW...100.00
250.00 NOW...175.00
LOSI 8-T.........
Tamiya M03-M
Motors.....
REC Pks........
RECEIVERS
RADIO'S.....
ONROAD FOAMS....
42sch (2)
Thank's.......
_________________
50.00 plus ship....
3rd is 180mm......
PM sent
Also take
I'll also take the raytech temp gun and a 2nd spektrum micro receiver.
You will be shipping everything to Kentucky 42303
Robbie
Robbie
Responded to your PM.
