Keeping Carbon Fiber Looking Decent
I'm still pretty new to racing on-road, but am hooked. Over the past few months I've purchased a used car, and recently purchased a new car.
I like my stuff to look decent, but we race on an asphalt track with the "road dots" (sorry, I'm not sure what they are actually called). I put one of those "film protectors" on the bottom of the new car, but the used car isn't looking so hot underneath. Both cars aren't looking so great where the battery sits.
Is there something that people use to keep things looking good (not looking for miracles, just for it to look better). Plastic polish doesn't seem to do much...
Sand smooth and brush on some Minwax urethane clear.
raise the height is good solution, when the asphalt track are uneven.. there are bound to be scratches... especially on the rear chassis.
for my case i check & replace the screws. if not i would have problems to change the suspension mount..when the screw thread wears off.
the skidplate is good enough to overcome the prob... for 1/10 touring.
I use wide re-enforced strapping/pakaging tape on my car to keep the chassis bottom pristine. Works well & is cheap.
Looks like crap though, so may not be what you're after
Added bonus is it also protects the screws & is so cheap I can replace/recover often.
Off road racing may not be the thing for you, but the coating would be a good thing when its new.
Goto your local hardware store and get the Tremclad clear coat in a spray can. Put 3-5 light coats on it, then hit it with a buffing wheel. Looks better then new.
Shawn.
Shawn.
