Drifting?
#31
i got 2" but i brought my wheels with me to the hardware store to make sure it was a good fit. and i went over to the electric department and they had gray pvc conduet . i had my front camber at -4 but did not like it now it is set to a 0 and it was alot more fun im running my 4-tec with a 17 double and 18/87 gearing . ive got plenty of torque .
#33
Originally posted by Nrctc3
Do you glue the PVC to the rim, or just slide it on?
When the pipes are gone (takes quite awhile), they become thin enough to slide off the rim and u can install new pipes onto the rims.
I recommend getting rims that are a little softer rather than those that are hard and brittle, this is coz I broke the hub area of a hard brittle rim before after just a light bump against the wall and the pipe being hard and all just makes the shock of the impact a little too much for the hub hex area. Besides, its easier to slide on a pipe if the rim crumples a little.
#35
is there a difference between the grey & white PVC? As far as thickness or hardness?
#36
Basically you set camber to get even wear on the pipes, coz they can cone alot and shorten the usable life of the pipes, not that it matters
#37
i picked up some PVC this morning. the guys at the local hardware store are cool, they let me lose in the back room with a scrap peice of 3 foot, 2" diameter PVC (the white stuff) a vise & a pipe cutter. I had 16 drift tires cut in about an hour and still have over a foot of PVC left. grand total $2.50 . i cut some of the PVC 26mm and some 31mm.
set the car up last night, changed roll center, ride height, shock oil & springs. i have no idea how it'll work but i'll find out soon. i even built a mild mod with lay down brushes for some punch. if it's too much torque i'll throw my 19t back in it.
gotta pick up a cool drift body soon, i'm thinking Altezza, blue with silver graphics & a carbon fiber hood + wing
#38
#39
Originally posted by Entropy
Lookin good dude. You can run a higher turn motor for longer run time and less maintanence like a 23 or 27 turn. It makes it easier to control the car.
#40
does anyone else have the 3rd installment of the sg drift vid??? rcdrift doesnt have it, and i cant connect to the frequency rc site...thanx in advance!!!
#41
This was from a drift class in Japan.
PVC wheels.
You don't need much power to drift, especially with these type of wheels. A 27T is plenty!
PVC wheels.
#42
some more speed would be useful
#43
this is a good PVC tutorial, its in japanees but the pictures are helpful and easy to understand...
PVC Tutorial
PVC Tutorial
#44
got the PVC on some wheels last night i went out with the car before work this morning to try it out. about half way through the first pack while "scuffing in" the fresh PVC i blew the rear diff must have been the helicopter style donuts with an 11t . i'm gonna put spools in the front & rear then put my 19t back in it. the PVC could use a little more bite, maybe it'll get better after it wears a bit. if not i'll try some grip-tape strips over the PVC . the PVC provides some long drifts but i'm gonna need some more practice to get the car going where i want it to.
Real Drifting= stupid
RC Drifting= sweet
RC Drifting= sweet
#45
i do i do
