Team Associated TC7.2 Factory Team >
Like Tree261Likes
Old 11-17-2018, 12:56 PM
  #271
Could be suspension tweak or uneven droop.
rcmuscles likes this.
grippgoat is offline
Old 11-17-2018, 01:19 PM
  #272
corallyman's Avatar
Trader Rating: 101 (100%+)
Originally Posted by ScottZ
anybody have a problem with the diff leaking i run a race and diff oil leaking out ? rubber o ring is in
Could you have over filled the diff. Most are now using a small digital scale which helps get it correct and for repeatability also.
Steve
corallyman is offline
Old 11-18-2018, 12:05 AM
  #273
rcmuscles's Avatar
Default Thx
Thanks the shocks/sway is good to go but tomorrow I’ll check the droop, right on
rcmuscles is offline
Old 11-18-2018, 12:06 AM
  #274
rcmuscles's Avatar
Default Yep
Steve
...this could definitely be the case... thanks
Old 11-18-2018, 12:46 AM
  #275
Trader Rating: 15 (100%+)
Randy of 1up gave a preview of some new suspension mounts along with the new DTCV2. Looks pro!
Randy Caster likes this.
trigger is offline
Old 11-24-2018, 05:30 PM
  #276
Any pictures of the dtcv2 ???
bertrandsv87 is offline
Old 11-25-2018, 09:59 AM
  #277
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I posted a few shots on my FB page a couple weeks ago. Working hard to get the new parts released before Christmas!
S_fender and Edwin Pibal like this.
Randy Caster is offline
Old 11-25-2018, 10:01 AM
  #278
Ok.....Thanks....
Old 12-06-2018, 07:57 AM
  #279
I know it was mentioned before, but I can't seem to find it. I know the x-rings are good for the shocks, but what are the best bladders?
JC3 likes this.
Megatron328 is offline
Old 12-06-2018, 11:55 AM
  #280
Yokomo BD8 bladders are a popular choice, those are fairly stiffer than stock bladders, good if you look for more rebound.
Fastfreddy74 is offline
Old 12-24-2018, 12:47 AM
  #281
Trader Rating: 166 (100%+)
Just received my kit on Saturday and have began building. When assembling the pullies, how are you gluing them?
jpcopeland1 is offline
Old 12-24-2018, 03:41 AM
  #282
jpx
jpx's Avatar
just a few dots of CA glue around, maybe use a pin to dispense.
Chamfered side to the inside.
jpx is offline
Old 12-24-2018, 12:03 PM
  #283
Ok. Thanks.
Old 12-26-2018, 09:05 AM
  #284
recommended gear ratios for a medium sized CRC black carpet track? Will be running 17.5 TC. Will be going 64 pitch.
Old 12-27-2018, 02:20 PM
  #285
Trader Rating: 23 (100%+)
What motor?
pcar951 is offline
