CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 03-27-2014, 09:50 PM
  #3691
Trader Rating: 16 (100%+)
Originally Posted by uscgretired
Bill,
Is there a post or setup sheet that describes your LE asphalt setup? I run mine on parking lot asphalt in club races and it is anything but easy to drive! Any help would be greatly appreciated.
Thanks,
Bill
Bill,
Other than carpet, I have only run my WGT cars on smooth high traction asphalt tracks. So, I am a bit spoiled when it comes to asphalt racing. For the most part, I was never successful with any form of parking lot races due to the lack of grip.
However, I would suggest placing the rear side springs out above the side links and running whites (old) or .45-.50 mm side springs at the rear. It should allow your car to handle the
imperfections of a parking lot type surface better than a standard setup.
Modifying SG1's posted carpet setup from last year using the outboard rear side springs with the side tubes raised at the outside is definitely where I would start to try to develop a parking lot setup.
Are there other WGT cars racing at the same parking lots with you? If so, how are they doing?
Bill
Still Bill is offline
Old 03-28-2014, 06:05 AM
  #3692
Trader Rating: 11 (100%+)
Still Bill,
Thanks for the suggestions, I will try them. I run it in our 2 wheel modified class against a bunch of trucks, I thought it would be fun to try a Pan Car but it is the only one.
Bill
uscgretired is offline
Old 03-28-2014, 08:25 PM
  #3693
Still Bill,
Bill
If those trucks are running 2S battery packs, you might want to try a 2S "shorty pack". More power and a bit more weight. It would not be an official WGT car; but, it should be a rocket down the straights.
Bill
Old 03-28-2014, 08:57 PM
  #3694
Originally Posted by sg1
Hey Bill,
My poor car is in a pile of pieces going through a rebuild, so I can't get a pic But, here's what I just ran:
1/12 kingpins with .50 springs with min. droop (.01" gap between stearing block and lower pivot balls while sitting on the table)
0* castor blocks with high roll center graphite shims
All castor shims back
1.5* camber and slight toe out.
2.01" tires, to purple line sauced
4mm clearance
new green center shock spring with 35wt. oil
2mm droop
.55 side springs (just touching)
20K in tubes (i did raise them like the LE)
2.05" tires ,narrowed (3/16" on insides)
4mm clearance
sauced 3/4 center of tire
Wayne,
And are the .55 mm side springs still out over the side links like before?
Many thanks.
Bill
Old 03-29-2014, 02:08 PM
  #3695
spring71's Avatar
Smile
2014 Roar Electric Carpet Regional will be held on April 6th at TQ RC RACING.
Click Here for the detail
FYI, Thanks.
spring71 is offline
Old 03-29-2014, 07:16 PM
  #3696
Bill
Bill,
Running a 2s shorty is a great idea once I get the car dialed in a bit more. The track is an oval about 45x90 feet so it can handle a bit of speed on the straights.
I am trying to figure out what to order from CRC for parts and springs to to try setting the side tubes level and moving/replacing the side springs so they are over the side links. In your post you mention white (old) springs, not sure what that relates to on the CRC web site. I see a #1296 side spring white medium...is that the spring? Or is it the #1793 - Pro Tapered Spring (pr) .50mm? I think I found the standoffs used by SG1 but not sure...I did read a slew of posts about his setup but no specifics with part numbers. Is there a post that has part numbers for the setup that I have not uncovered yet?
I am a newbie to the CRC and really appreciate all the posts and help!
Thanks,
Bill
Old 04-01-2014, 04:14 AM
  #3697
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by FL_SilverEvo8
What one are you liking more? The SE or LE? How far off are the set up's for both?
The LE can run a much softer set up (lube and springs) compaired to the SE. (for my driving style)
Some guys have told me they run the same set up, but it didn't work for me.
sg1 is offline
Old 04-01-2014, 04:16 AM
  #3698
sg1
sg1's Avatar
Wayne,
Many thanks.
Bill
The side springs are out past the sidelinks. That put them in approx. the same location as the LE.
sg1 is offline
Old 04-01-2014, 08:37 PM
  #3699
Thank you for the clarifications Wayne.
Bill
Old 04-01-2014, 08:40 PM
  #3700
FYI, Thanks.
And I will be there. Two of three WGT cars initially with SG1 setups...So, lots of work before my first practice day on Friday...After the 360 mile drive...LOL
Bill
Old 04-03-2014, 08:18 PM
  #3701
Odin544's Avatar
Trader Rating: 93 (100%+)
Odin,
Sounds like a good assessment. So far, I have never needed to add shims or washers there on a 1/10th kingpin; but, it could be useful for certain setups.
What is the distance from the bottom of the steering block to the bottom of the groove for the c-clip on the kingpin? Is it about 0.600"? Are both distances equal?
Bill
Bill the distance is 0.622" to the bottom of the c-clip groove on both side. The kingpins seem to be screwed all the way in without forcing them any further. The shims that were added amount to about .06". Without the shims there is some free play in the suspension before the springs start to compress at all.
I was going to put the 1/12 kingpins on but I somehow managed to order 2 sets of .55 and no .50's. I also managed not to get any other 1/10 front springs because I saw nothing that indicated what was 1/12 and what was 1/10.
I've got to say, CRC has one of the worst websites for ordering from. Makes me reconsider having this car over an AE. And thats no joke.
Odin544 is offline
Old 04-04-2014, 02:57 PM
  #3702
Trader Rating: 1 (60%+)
Selling a Crc gen10le...if anyones looking!
racer034life is offline
Old 04-04-2014, 04:24 PM
  #3703
With only 10 LIPO's:
To prevent: Limiting center shock or side? Another idea?
thanks and regards
TyoBBS is offline
Old 04-24-2014, 06:21 PM
  #3704
thanks and regards
Not sure what I am supposed to be seeing in the photo...
Bill
Old 04-24-2014, 09:52 PM
  #3705
Bill
Rear bottom plate (support for link part): chasis have less milimeters will broken in a few lipo's
regards
TyoBBS is offline
