My Firelap AWD Review and Build
My review and build of Firelap AWD iw04. First I do own 3 Kyosho Mini-Z MR-02, MR-03 and MA-010. All are great cars well designed and drive really well out of the box. I purchased Firelap as a cheap alternative for occasional friend or relative that comes over and does not really drive so well. So instead of smashing up my beloved Z’s, I will pull out the Firelap. I purchased two from Miracle-Mart, a iw04 and iw02 for a total price of $141 shipped. I will review the AWD first.
The AWD link to specs: iw04
Here is what I got:
Outside of body:
Body is not as nice as the Mini-z, but the kyosho body will fit these chassis. Looking from underneath the body is a one piece molded clear and painted.
Top cover removed:
Looking at the front, it comes with differential bearings, metal dogbones and 3 wire servo:
Look at rear, this was a nice surprise, it has bearings installed on drive shaft already. The Differentials look the same size as the Mini-z. Did not try swapping.
Looking at the electronics, fets were unable to read? I wonder why.
I soldered Losi Mini-T connector for transponder direct to power switch so it will power on/off with switch.
Looking at hubs, come with plastic bushings, installed 3 Racing bearings for Kyosho AWD.
Next was gear lubing, I use a wax lube, makes gears quieter and smoother. Just put small dabs and let dry.
Finally motor break-in, I use the water method, the motor is not very good and does not come with caps. I will run it with stock motor for little while before replacing it.
Ok, now to put it all back together. It does come with drift tires and some other gears so you can adjust the length for other bodies.
Drive test, it handles very well actually much better than I though it would steering is responsive and predicable. However it is kind of slow compared to my Mini-z. But my Z has X-speed motor. Bad comparison, I would compare it to the xmods days with the stock motor. The plastic on some of the parts may need to be trimmed because of imperfect molding. (not a big deal all parts are right shape and do not affect functionality of car) Overall not a bad kit. Recommended upgrades are bearings for wheel hubs and motor. Then you have a decent car.
Here is what I got:
Outside of body:
Top cover removed:
Video added
http://youtu.be/xaB1azoc3Zs
Feedback welcomed. Let me know what you guys think. Any cheap upgrades recommended.
Good review hlim637.
i have one not a bad car but it does not have a brake, one thing i don't like about the car.I can't see why they did not put a brake function on it.Also kyosho knuckles do not fit wish they did cause u have so many knuckles for the z.
Know this is old thread but just got the new improved FIRELAP awd with color screen radio.much better also has new ESC and has a brake car runs great for the price.the plastic now is gray top plastic piece could of been better but still holding up good going to get the carbon chassis and some other parts.
Mini Z Firelap 1/28 scale 4WD + 2.4Ghz TX with "Colour Screen"
In response to your question, I think I may have found a link :
Step 1 - go to Lightinthebox.com
Step 2 - go to all categories and go to Sports and Lifestyle
Step 3 - from there, go to Toys and Hobbies
Step 4 - then go to RC Cars
Step 5 - In the filters check the boxes for Car (On-road) (in car type) and Brushless Electric (in source of power)
Step 6 - If you want to see all of the available bodies, you have to click on price so it will show you the prices from High to Low.
Hope this response was of use to you and anyone else
