Serpent 710
Originally posted by Picard
Your running Red and Yellows arn't you D?
Originally posted by InitialD
Onkel Sow is very ellusive about his setup. Perhaps Mark is reading somewhere here. Remember they will go against each other on the track this weekend.
So he tried to throw me off with all that Roll centre talk in the hope that I will forget my question
Well then sow PM me and I promise I will not tell Mark
got my brake fix lost my otuer gear lol hwo u like my new body?
Yes, that's Onkel Sow alright. Probably tried to confuse Mark who might me reading that too.
With the red springs on the rear are you running the new rear roll bar or the standard and how far in is it set?
foudn gears the body fits good
Got to go kick some ass (or get my ass kicked) this morning.
I use the old stock one (2 mm). I set it about 12 mm from the end but the sway bar is mounted on the inner side of the lower rear arm (not outer as what the manual suggest).
Originally posted by Sow&Steady
Following on from my previous question, isn't the 35W Serpent oil more suited for the Red springs?
Trinity 40WT is the equivalent of which Serpent oil?
So Pyramid, this is a good point.
As a guideline, what oil do you use for which springs?
The kit comes with 30 - Yellow.
Uncle Sow, looks like you have FET fingers now.. you`ve been writing a lot on your website. Makes me looks much slower now to catch up will the reading and all..
The 710 kit comes with 30w oil. I heard a while back that the weight is different from other brands. Serpent 30w is the same as Trinity 70w? BTW what Serpent shock oil weight would yo recommend on a high bite smooth track?
Exactly D. This is what I have found as well and what I have been saying. I also run the high front roll centre and the car feels fantastic IMO
Front bulkhead low => rollcenter high. Slightly less grip but faster response.
Front bulkhead high => Rollcenter low. Less response more grip on throttle.
