Team Associated T5M Discussion >
Like Tree108Likes
Old 08-18-2015, 08:58 PM
  #2071
NeedsHobbyMoney's Avatar
I run a fan with the MIP gearbox and temps are coming off at 120, as opposed to 169 with the same gearing and 4 gear with no fan.
NeedsHobbyMoney is offline
Old 08-20-2015, 02:57 AM
  #2072
Braxamus's Avatar
might be a dumb question, but in the instruction manual, when assembling the battery hold downs it shows 2 red o-rings, do they just go over the posts you screw into the chassis or do they go in the groove on the thumb screws? The manual dont say any thing and does not show a assembled pic just exploded.
Braxamus is offline
Old 08-20-2015, 03:35 AM
  #2073
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Orings go on bottom of thumb screws.
KAWIDAD is offline
Old 08-20-2015, 04:37 AM
  #2074
Trader Rating: 36 (100%+)
I decided to get a t5m and sell my 22t 1.0 with upgrades. What are the must haves for this truck, any aftermarket stuff that makes a difference, or do any of the brass weights make a big difference. Will be running on a indoor med bite track. Thanks
mxturd is offline
Old 08-20-2015, 05:30 AM
  #2075
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
I had my first run with my truck on Tuesday. The truck is great out of the box I changed to a Yellow spring in the front, Lunsford HD turn buckles and a 3 gear transmission. Im running on medium-high to high traction. I have my 2wd buggy decked out with aluminum but im leaving this stock and just running it.
BIGSKI15 is offline
Old 08-20-2015, 07:01 AM
  #2076
Trader Rating: 83 (100%+)
Depends on whether you are running stock or mod. Stock I built with as much titanium as possible for won't savings. Also the three gear Transmission.
dpcardoza is offline
Old 08-20-2015, 09:10 AM
  #2077
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Just to clarify if Braxamus is still unsure, the orings go into the groove in the thumb screw. The orings will be between the thumb screw and the plastic battery brace.
SEF is offline
Old 08-20-2015, 09:31 AM
  #2078
Will be running mod, just asking because it seemed like my 22 responded to some weight pretty well
mxturd is offline
Old 08-20-2015, 09:43 AM
  #2079
Braxamus's Avatar
Thanks for the info guys. I just built mine last Sat. still waiting on new batteries and ESC/motor I did buy the Brass "C" mount and front and rear alum. hinge pin braces as well. can't wait till our first race. still up in the air on which spring kit to buy as they seem to have a couple different sets. will only be running indoors, on a large high bite well groomed 1/10 track. so not sure to get the soft set or med. set.
Braxamus is offline
Old 08-20-2015, 09:53 AM
  #2080
I really like my Kyo gold spring, highly recommend them.
Old 08-21-2015, 12:11 PM
  #2081
Braxamus's Avatar
Without breaking the bank, what would be a good dependable servo for this.
Braxamus is offline
Old 08-21-2015, 12:30 PM
  #2082
KAWIDAD's Avatar
I run savox 1257. It has been a great servo for me as it has been in a sc10.2,22-4 and now my t5m. Think they are around $50.00.
KAWIDAD is offline
Old 08-21-2015, 01:58 PM
  #2083
Default +1
+1 that or a 1258, seen them run at my track for years and not break.
Old 08-21-2015, 02:13 PM
  #2084
Regional Moderator
RobsRacin's Avatar
Trader Rating: 13 (100%+)
I have Spektrum 6040 servos in all my 10th scale stuff and they are tough as nails and quick too. I have yet to break one even with alum. horns
RobsRacin is offline
Old 08-22-2015, 02:59 AM
  #2085
Braxamus's Avatar
Looking at all them servos I noticed they all are digital and the savox mentioned something about external BEC on some ESC's I am going to be running a SMC ESC so would I need to get something else to run these servos? I have never ran anything digital only std Futaba's and Spektrum's
Braxamus is offline
