BCE vs. Fioroni
BCE vs. Fioroni
Considering buying a lightweight chassis for my D8. Which would you choose?
BCE, Tekno or Hot Bodies Lightweight or even lightened chassis by WB-RACER-ACE
Fioroni is piece of junk. It is not even cut right, Bottom holes are not countersunk enough. Had it for one race, threw it away.
This year I have Tekno to try as I like the fact that you dont need center diff spacer unlike 3mm chassis like BCE or Fioroni where you need to get your hands on truggy diff spacers to move your diff up a bit so it does not stick from the chassis.
and BTW you can go wrong with lot of stuff from Fioroni Like their useless LIC driveshafts that break after few minutes. Seen like 5 broken CVDs on Mugens during one race. Or the mugen front shocktower protector break too easily.
Fioroni vario clutch is ok but thats about it.
The D8 chassis you mentioned does look sweet:
http://www.teknorc.com/product_info....oducts_id=1043
http://www.rctech.net/forum/nitro-of...nary-tale.html
..you should be on wallstreet with your excellent cry and sell techniques........
I hate these kinds of threads because they just drag out into long arguments. I run for BCE, but what I looked for when purchasing my chassis was the race history. If Ryan Maifield, Scott Hughes, Ryan Cav, Rhonda Skelton, Richard Saxton and many more well known drivers chose to use a BCE Chassis then that was a plus for me. Quality is top notch, you have to put washers under the center diff but they are included. IMO having to do that shows me how much lower the Center of Gravity is which is always an advantage on the track. The anodizing is great on the BCE Chassis and they are as durable as any other. BCE was the first 3mm chassis to come out for the D8 and now even Hot Bodies is testing a 3mm chassis which will most likely come out before too long. You can go wrong with the BCE. If you get one you will see first hand.
With all the talk about what chassis is better here is what i am going to do i run the Tekno chassis but i am going to bolt on a BCE and test it at my next comming race which will be around the 20th and i will give my honest review about both so maybe it will help people decide even tho i am sponsored by Tekno it will be an honest review if the BCE performs better i will tell everone the differences in performance.
Cheers, Mike.
