How do i wire 2 bullet lipo's? (RC8E)
Make a jumper like in the photo.
Use these. http://www3.towerhobbies.com/cgi-bin...&I=LXJPY4&P=ML
They have a notch in the side so you can build them at close to right angles.
Here's mine:
Here's mine:
http://www3.towerhobbies.com/cgi-bin...?&I=LXTJH8&P=7
The hole near the end of these connectors is for the same reason - 90 degree soldering.
Here's mine:
Here's mine:
But I will drill some since I already have a ton(not really) lying around.
Here's mine:
Here's mine:
Also, how do you have your lipos wired so you can use 2 2s packs instead of one bigger pack?
Batteries using female bullet connectors will use a 4mm male connector.
