SpeedGem Extreme Series
SpeedGem Extreme Series Motors
Just went to trinitys website and found they have a new speedgem series.
The Speedgem Extreme
http://www.teamtrinity.com/htm%20pag...gemextreme.htm
Features:
D-6 Can & Endbell
Trinity FB-9.four, 4 magnet system
Dual ball bearings
Adjustable endbell timing
Pure copper endbell brush hoods for super low resistance
Brush hood damper system for brush stabilization
3 installed capacitors, nothing to solder
"No Solder Leads" plugs right into the speed control
New hi-performance long wear brush compound, TRI 13503
High-performance spring set-up
Machine wound on hi-torque, hi-power, hi-effeciency armature blanks
Biggest gauge, lowest resistance wire for more power
Diamond trued commutator
Epoxy balanced
Dyno tested, tweaked and tuned
High-qualityl, hi-cost Japanese precision components at affordable pricing
Description:
The New Trinity "SpeedGems Extreme™" Line is the fastest machine wound motor you can buy for any R/C truck, car, boat, or plane. In today's soft economy othr R/C motor companies have resorted to using lower grade, cheaper Chinease components for their machine wound motors to keep down the production costs. This is good for them but for the racer it translates intor a loss of performance and reliability, and it turns their motors into a disposable commodity instead of one that may be rebuilt, tuned and raced time after time. Trinity on the other hand has raised the stakes by moving our machine wound SpeedGems Extreme motors to one level below our best hand wound modifieds. The "SpeedGems Extreme" motors share the same lineage as the popular and extremely fast D-6 modifieds. Besides making the fastest and most reliable machine wound motors, Trinity is the only company to offer replacement armatures and components to keep your motor running line new. We let you rebuild it instead of simply tossing it.
By utilizing the same can and enbell as the D-6 and combining it with a mcachine wound armature we have managed to make the fastest machine wound modified motor that offeres hand wond performance for a fraction of the price.
Packaged In Trinity motor blister packaging.
Item Number & Retail Price:
UPC Part Number Description Retail
690776083477 TRI10054 SpeedGem Extreme 10 Double $59.99
690776083484 TRI10055 SpeedGem Extreme 12 Double $59.99
690776083491 TRI10056 SpeedGem Extreme 13 Triple $59.99
690776083507 TRI10057 SpeedGem Extreme 15 Double $59.99
690776083514 TRI10058 SpeedGem Extreme 17 Double $59.99
Says the will be out in OCT? So is this 2005 or just passed OCT?
Im also wondering why they went and took the speedgem series and just made it the best ever as before it was meant to be a budget series??
Oh well, I might just get one as this is right up my alley.
Features:
D-6 Can & Endbell
Dual ball bearings
Epoxy balanced
Description:
Re: SpeedGem Extreme Series Motors
By utilizing the same can and enbell as the D-6 and combining it with a machine wound armature we have managed to make the fastest machine wound modified motor that offeres hand wond performance for a fraction of the price.
It's simple. They're using last generation technology and tools, to create pretty decent motors at low price. But of course machine wound.
