YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 03-25-2015, 06:15 PM
  #5641
b20btec's Avatar
Trader Rating: 11 (100%+)
Originally Posted by onroad dude
does anybody have a photo of how the chassis weights are supposed to mount?
b20btec is offline
Old 03-25-2015, 06:18 PM
  #5642
b20btec's Avatar
Which weights do you have? There's two versions of the front and rear. New versions front 10g with pin as oppose to 15g and rear is 30g with pin.
b20btec is offline
Old 03-25-2015, 07:03 PM
  #5643
Trader Rating: 13 (100%+)
the 15g ones
onroad dude is offline
Old 03-26-2015, 04:56 AM
  #5644
b20btec's Avatar
the 15g ones
I will take a picture for you later today installed on a chasses. Keep it mind the 15g will not fit if you're running a xray servo saver, you will need BWF10, the 10g version.
b20btec is offline
Old 03-26-2015, 07:46 AM
  #5645
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default DCJ rebuild
I had a DCJ fail on me and was wondering is there a good way to prevent failure it was the nub on the axle that connects to the axle bone. Any help would be good thanks Chris
bigcracing is offline
Old 03-26-2015, 10:25 PM
  #5646
El Asso Wipo's Avatar
Default Who's Running Yokomo USA now
Is Robert still team manager these days?
El Asso Wipo is offline
Old 03-27-2015, 03:30 AM
  #5647
Lonestar's Avatar
Trader Rating: 14 (100%+)
Interesting comments a few pages ago about what is the one single setup change to modify the car
re chassis weights... I run wheel balancing weights on the electronics side. Cheaper than the yokomo ones, and 15g fits easily with the xray servo saver
Paul
Lonestar is offline
Old 03-27-2015, 05:51 AM
  #5648
b20btec's Avatar
the 15g ones
I took a picture for you, but unfortunately it's no help, I forgot my phone at home.
Quick google search revealed a picture that may help you.
b20btec is offline
Old 03-27-2015, 05:54 AM
  #5649
b20btec's Avatar
Which version DCJ is it? Pin type with set screw or the DCJ version with locking clip? If you're running the pin type it's prone to breaking, even with a slight bump of the wheel. Most have switched to the locking clip or other brands like MR. Roche and Spec R. I like the Roche, it has served me well.
b20btec is offline
Old 03-28-2015, 03:42 PM
  #5650
bigcracing's Avatar
It is the pin type with set screws. Should I switch to the clip type? Or just get a Roche
Old 03-28-2015, 03:46 PM
  #5651
b20btec's Avatar
I had success with either, including the spec R, as long as it's the C clip type.
b20btec is offline
Old 03-28-2015, 06:23 PM
  #5652
Moderator
DaveVera's Avatar
Yes he is, but there no longer is a Yokomo USA. However, you can pretty much get everything from Amain, Tq hobbies, etc....
DaveVera is offline
Old 03-29-2015, 05:47 AM
  #5653
Bought myself a yokomo 15 second hand
Didn't come with the double jointed shafts
What's the size of the inner bearings needed for the roche double jointed shafts
And what's the size of the pin that goes through the roche double jointed shafts
CLovely is offline
Old 03-29-2015, 02:24 PM
  #5654
Trader Rating: 12 (100%+)
When filling the rear gear diff with fluid, whats the proper fill point? In the manual it looks like they just cover the satellite gears. But People say to just cover the top pin.
kobiwan is offline
Old 03-29-2015, 03:29 PM
  #5655
bearing is a 5x10x3
the pin is a 1.6mm
